Headers and x pipe cheap on eBay
Please post listings of vendor sales, deals, coupon codes, or hot bargains ONLY. No individually-owned items for sale here please. Listings by members with under 5 forum posts may be removed without warning.
Just found these on discount they seem to work with possibly a tap or two of hammer https://www.ebay.com/itm/154683041164
Re: Headers and x pipe cheap on eBay
being for the SS sedan , there should be nothing done to the headers
but the mid section will require work , because of the longer caprice , and the different muffler flanges
I found one post of a guy that said he has them installed on his car just needed one primary on each dented for clearance and the add also says some slight modifications may be needed but for stainless 2in primary’s and 3in x for 630 I’ll take gamble
Oh, this is awesome. I want a set of these.
Might be like mine where you'll need to notch a header tube to clear the steering shaft.
But looking closer at the pics, those are some ugly ass welds at the header flange.
Here's Maximizers as a comparison, which are the ones I went with:
I went with a Maximizer system from headers to rear pipes and JBA mufflers however the flanges at the muffler didn't match and the tail pipes had to be extended to fit the longer Caprice body. I can't find that particular Maximizer system anymore.
If you can live with those welds, the JBA mufflers are really nice to go with it. Just check that the flanges match.
Those headers must be welded from the inside. Yikes.
They are on order so we will see what they look like in a couple days
Just came in they don’t look to bad I can live with that
- C99F6687-294F-4438-A8D3-11027744E422.jpeg (2.71 MiB) Viewed 2478 times
- 33917451-24B0-4B27-ABB7-2D1152928BA1.jpeg (2.51 MiB) Viewed 2478 times
I don’t think they look bad at all, I hope they fit well too.
Ill keep everyone posted after install they seem to come with everything also bolts gaskets clamps and o2 extenders
