Cold Air Intake
Tech discussions on the 3.6L V6 motor (LFX) used in the 2012 & up Caprice.
ColoCapriceGuy
Cold Air Intake
Post by ColoCapriceGuy »
Has anyone fitted a cold air intake on their 3.6?
I have searched google with 3.6 SIDI and have found OTR Kits for $500. $500 is a little bit too much, however, it appears maybe a 3.6 camaro intake would work. Those intakes are much more affordable at $100. Has anyone tried that?
ColoCapriceGuy
Re: Cold Air Intake
So the 2012-2015 LFX Camaro intakes $80-$100 will fit with minor adjustments to the heat shield. There are some smaller heat shielding options available which may not need any trimming however.
This is a lot more affordable than $600 for a OTR solution on a V6. Hope this helps!
StevenJay
Re: Cold Air Intake
Post by StevenJay »
I have a CAI for a v6 that I order from Australia that routes the intake down to the front bumper/wheel well area which is where it should be pulling air from. It's still in the box and I went supercharged so I'm not going to install it. Email me at [email protected] if you're interested.
Steven J.
Users browsing this forum: No registered users and 6 guests
