Horn not working
xten57
Horn not working
Post by xten57 » Wed Sep 15, 2021 7:50 pm
Hello, all,
My horn had been working normally, and now it does not. I checked the fuse (F8 in the under-hood panel) and it was good, but I replaced it with a new one just to verify. Still no horn. I've read through a bunch of other threads on this site and can't find a solution. Everything else on the steering wheel still works as it did before the horn failed, so I don't know where else to look. Is there another fuse that could also control the horn circuit?
Any suggestions for trouble shooting would be greatly appreciated.
Thanks in advance,
Gerry
Re: Horn not working
Post by smwalker » Wed Sep 15, 2021 11:46 pm
What year?
In the 11-13 it's a brown wire
In the 14+ it's a Green with a white stripe
both in the passenger footwell:
More info here:
viewtopic.php?f=21&t=2393#p19287
xten57
Post by xten57 » Thu Sep 16, 2021 1:54 am
Thanks for your reply, Steve. My car is a 2013 9C3. I'll check for a broken wire, although I can't understand how that could happen. The horn was working fine.
Gerry
xten57
Post by xten57 » Fri Oct 01, 2021 10:13 pm
Is there more than one fuse controlling the horn? Any relays?
Thanks again,
Post by smwalker » Mon Oct 04, 2021 9:47 pm
Yes fuse and relay controlled by the BCM both model years:
WN - 2014 + : https://www.chiltonlibrary.com/content/ ... 601720.pdf
WM - 2011- 2013: https://www.chiltonlibrary.com/content/ ... 662598.pdf
xten57
Post by xten57 » Sat Oct 16, 2021 12:28 am
Steve, thanks again. I found the relay, it's R16 in my 2013 fuse panel. I checked it and it's good. However, I dug around under the glove box and found a pair of wires that had become disconnected from a butt connector. I cut out the connector and replaced it with a good one, and used some good crimpers to re-make the connection.
Now, I have a horn again.
Thanks to everyone else who helped on this.
Gerry
