Error p0522 low voltage engine oil pressure
Posted: Fri Mar 19, 2021 5:04 pm
by skialpentolic
I got a new sensor and discovered the plug was loose and easily slid on and off the sensor. It failed to clip or securely fasten to the new part. I guess I need a new plug and slice it in? Anyone have this problem.
I also recently put a stage 1 BT cam and ported heads on.
Re: Error p0522 low voltage engine oil pressure
Posted: Sat Mar 20, 2021 11:10 am
by Mooseman
Does it still clip correctly to the old sensor? Could be the new sensor. I had that once on a new alternator where the connector wouldn't go in deep enough. Shaved a bit off the end of the connector on the alternator and it clicked. Could be a very small difference in length where the connector hits the bottom of the plug before it can click.
Posted: Sun Mar 21, 2021 12:40 pm
by skialpentolic
When I went to look at a replacement plug I noticed that the fastening mechanism was missing. Think I got it. Unfortunately I may have to slice.
