Steering Wheel Shake
Re: Steering Wheel Shake
Hello, I have changed every part in the front suspension except inner tie rods it get better but still the steering wheel shaking any one know how can I solve this problem ( 2015 ME caprice)
Saud,
Did you replace the lower control arms and/or bushings? Would you have a broken belt in a tire?
Yes already replaced for both wheels right and left with a new original arms it got better but still shaking, also the tire bolts are good
Could it because the inner tie rods?
- waipunalei
Did you ever figure out your shake? I've got the same symptoms
When I first took possession of my car I had a steering wheel shake. It'd come and go.
New tires didn't help, so I ruled out balance and dug deeper.
Everything I did made it slightly better. Every part I replaced showed obvious wear and tear.
Strut mounts
Outer tie rods
Inner tie rods
Alingment
At this point there was only a shake in right turns at a certain steering angle.
Sway bar end links
Sway bar mounts.
Better but not gone.
OK, FINE!
Struts.
Left side control arms.
Alignment
Steering wheel shake starting at 50 that got worse until about 85 and came and went over about a 40 second cycle.
Did a tire rotation and the shake moved to the back...
Had the balance on the tires checked.
2 tires were 1/2 ounce off.
1 tire was 1 ounce off.
All is smooth now!
It's a dang process getting this sorted out. It took me almost two years of picking at it to get here, don't give up!
Strut mounts
Outer tie rods
Inner tie rods
Alingment
Sway bar end links
Sway bar mounts.
OK, FINE!
Struts.
Alignment
All is smooth now!
