Big Single TURBO build ...LOADING
Re: Big Single TURBO build ...LOADING
I got the other half wrapped yesterday, and made a dump for the bottom wastegate.
- 20190501_174748.jpg (3.48 MiB) Viewed 16776 times
2012 Chevy Caprice- VSR80 turbo, BTR stage 2, 3.45s, camaro wheels, meth injection (racecar/ weekend car)
2007 Honda Civic SI- Sedan- intake, exhaust, Skunk2 short shifter, shift bushings (wife's daily)
2005 Chevy tahoe- Cold air intake, everything else stock! (The family car)
2000 Honda civic Hatchback- lowered, rota slip wheels. (My daily)
Wrap
- 20190502_190000.jpg (4.18 MiB) Viewed 16776 times
I have the hot side all mounted up aqa, with both wastegate on. Still need to do vacuum lines to those.
- 20190502_231201.jpg (3.32 MiB) Viewed 16768 times
- 20190502_230637.jpg (3.25 MiB) Viewed 16768 times
- 20190502_230617.jpg (3.68 MiB) Viewed 16768 times
Here's a quick picture with the blanket and intake on the way it'll be.
- 20190504_103852.jpg (4.07 MiB) Viewed 16751 times
Got the methanol tank mounted in the trunk. I'm getting really close to being done!
- 20190504_174707.jpg (3.43 MiB) Viewed 16750 times
I picked up this gauge pod on Amazon for $14. I heated it up with a heat gun and pressed it onto the dash to get it a little more flush. Here is how it sat before the heat. Link below if anyone is interested.
GlowShift Universal Black Triple Gauge Console Dashboard Pod - Fits Any Make/Model - ABS Plastic - Mounts (3) 2-1/16" (52mm) Gauges to Vehicle's Dash https://www.amazon.com/dp/B000HDFJ9M/re ... 0Cb4VRNDR9
- 20190506_163112.jpg (3.5 MiB) Viewed 16725 times
Here's a picture after the heat gun treatment. The gauge was a little difficult to get in. I sanded the hole a little and it worked fine.
- 20190506_191608.jpg (4.01 MiB) Viewed 16725 times
- 20190506_191413.jpg (3.94 MiB) Viewed 16725 times
- 20190506_191336.jpg (4.2 MiB) Viewed 16725 times
Here's a picture with the downpipe on. I was gonna plumb the wastegate into it, but I think I'm just going to cut another 2in hole and dump it right next to the 5in. Also im going to paint the downpipe black so it blends in a little better
Also I started wiring the meth injection. The AEM kit makes it super simple. The only thing I haven't figured out is how to get the wires on the dash to where the gauges go. I really dont want to drill into the dash
- received_360899797861458.jpeg (841.23 KiB) Viewed 16702 times
- received_2344366319221006.jpeg (622.98 KiB) Viewed 16702 times
Haven't even plugged HP tuners in yet and I already gained a few HP
- 20190512_184524.jpg (3.44 MiB) Viewed 16651 times
- 20190512_184436.jpg (2.12 MiB) Viewed 16651 times
I'm surprised the rear tires don't light up every time you open the trunk with all those stickers!
