I alluded to this here, in discussing other aspects of Greg's wheel/tire setup and future spring changes (full thread in Wheel/Tire section):
The shocks are made by Monroe in Australia, and are low-pressure gas charged. I do not know if they are mono-tube design, but I don't think so--I'm not aware that Monroe makes any mono-tube (with divider piston) shocks, as in the deCarbon/Bilstein design. There are other shocks available in the aftermarket--G8 & PPV front suspension are the same as far as fit/form/function of both shocks & springs.Navy Lifer wrote:I've also learned (and confirmed by looking at the parts info) that the 2011 PPV used a shock package developed by Holden, where the 2012 & 2013 PPV have a shock package developed by GMNA engineers, and is reported to be much better. I'm going to use the new-spec shocks when I change springs, so it will be a learning exercise.gregc wrote:No problems with the Camaro TPMS. The tires can withstand the 42 psi threats required for the Capricebkwagonss wrote:No problem with tire pressure monitors with the SS wheels?
They have different tire pressure than the Caprice tires.
How does it know what is correct?
PN's for 2012-2013 PPV shocks:
92263478 Strut, RF
92263479 Strut, LF
92258191 upper mount kit for front struts (2) - aftermarket also can supply these
92263480 Shock absorber, rear (2) - R & L
(This shock also installed on 2011 PPV produced after July 4 2011 & VIN BL565468)
FWIW, G8 GXP uses a specific front strut, G8 GT & GXP share rear shocks & springs, but GXP uses a specific rear sway bar. None of the PPV springs or shocks are common with G8 as far as original spec, but the common platform would allow use of G8 shocks & springs on PPV & vice-versa.
