Nope, it's a socket that pops into place when you push straight down (just make sure the pin and socket are lined up), or remove the seat by first pulling straight up on both front corners.cerbomark wrote:Thanks, so I assume it bent. going back at 45 degree angle.s/c'd cav wrote:should be up and down
picked up 2016
Re: picked up 2016
Re: picked up 2016
CrashTestDummy wrote:Nope, it's a socket that pops into place when you push straight down (just make sure the pin and socket are lined up), or remove the seat by first pulling straight up on both front corners.cerbomark wrote:Thanks, so I assume it bent. going back at 45 degree angle.s/c'd cav wrote:should be up and down
Won t lock in. other side locked in and I don't want to break that side. Don t pop out easily.
I looked down into the clip and doesn't t seem broken either.
2016 C1
Re: picked up 2016
How did you remove the rear emblem without damaging the paint?
Jim
Jim
Jim Chesnutt
1968 Camaro -my first car.
1995 Black/White 9C1 Caprice
Re: picked up 2016
Just get a little fishing line and saw it thru the back. Then just get glue and padding of with your nail. Then alcohol wipe and wax.
2016 C1
Re: picked up 2016
Cool! Thanks!
Jim
Jim
Jim Chesnutt
Re: picked up 2016
Cool! Thanks!
Jim
Jim
Jim Chesnutt
Re: picked up 2016
Just plugged in the AFM delete by Range. Drove about 10 miles and all working fine. Need to get more time to be sure it won t set anything off.
16 doesn't t display v4 or v8 like other years but I can easily feel it.
Dealer recalls tomorrow.
2016 C1
Re: picked up 2016
AFM delete has been working as advertised for about 200 miles now. Unplugged at dealer visit.
Tints done and rear emblem gone.
To my surprise while getting two recalls done, the dealer ordered a few interior clips that were broken by the last owner.( under warranty ).
2016 C1
