Hi New here....Thanks for a great web page for us to use. Question .....Will 9C3 hubcaps fit on 9C1 steel wheels if you remove the dog dish style center cap?
Hubcaps
Re: Hubcaps
Yes. My 2011 already had the 9C1 caps swapped out for the 9C3 hubcaps when I got it. They are the same wheels- with the 3 small threaded holes. The full size wheel covers are secured e the plastic lug nuts on the cover so assuming you have the lug nuts with the extra external threads, you should be good to go
- KIMG0226.JPG (126.69 KiB) Viewed 9716 times
2011 9C1 6.0
Flex fuel tune
Flex fuel tune
Re: Hubcaps
ok great thinks...... I .may need the special threaded lug nuts
Re: Hubcaps
The wheel covers should come with the plastic nuts. The lug nuts need to look like this:
- KIMG0228.JPG (114.04 KiB) Viewed 9679 times
2011 9C1 6.0
Flex fuel tune
Flex fuel tune
Re: Hubcaps
thanks for posting the picture......I will need those for sure
