2014 Caprice PPV - YouTube Project Car
How-To Remove/Install Rear Seat
I show how to remove and install the rear seat in a 2011-2017 Chevy Caprice PPV as well as the 2014-2017 Chevy SS Sedan.
https://www.youtube.com/watch?v=nMnnXUketCc
Rear Axle Wiring Harness Tape Problems
I have a video I created back in 2018 that talks about a customer satisfaction campaign 15803 (not a recall) for the 2014/2015 Chevy SS / Caprice PPV rear axle wiring harness tape problem.
It's worth the few minutes it takes to check if this work was performed to your 2014-2015 Caprice PPV.
https://youtu.be/BxjEu_SRA3k
Aluminum Pedal Cover Installation
I show you why I installed an aluminum dead pedal cover with spacers. I also install aluminum brake and accelerator pedal covers used in the Chevy SS Sedan in my 2014 Chevy Caprice PPV.
https://www.youtube.com/watch?v=n1RgSlk97Rg
Add a Backup Camera / Activate XM Radio Receiver
This video gives you an overview of how I added a backup camera and activated the XM Radio receiver in my 2014 Chevy Caprice PPV.
https://www.youtube.com/watch?v=OlpnwMzyoMs
2014-2017 Chevy Caprice PPV - Remove Fleet Keys / FOBs
I give you an overview of the steps I performed to have my 2014 Chevy Caprice PPV no longer accept fleet keys nor FOBs from RPO code 6E3.
I also show you what I did to repair the FOB antenna in the rear window of my car.
https://www.youtube.com/watch?v=iSn7_8RNiJM
14-17 Chevy Caprice PPV - HVAC Afterblow / XM Radio Antenna / Front Sway Bar Bushings
I show you some of the minor mods I made to my 2014 Chevy Caprice PPV while I was waiting for the parts to repair the failed fuel pump.
I also document what the HVAC afterblow feature is and how you can use a scan tool to enable that feature in the HVAC control module.
https://www.youtube.com/watch?v=zPWym8-XEnc
2014-2017 Chevy Caprice PPV - Install Front Splash Shields
I needed to replace the front splash shields on my 2014 Chevy Caprice PPV after I worked on my car to replace the front sway bar bushings.
The driver's side splash shield broke into pieces and the passenger side splash shield was not installed.
https://www.youtube.com/watch?v=MQjC938V7Ys
2011-2017 Chevy Caprice PPV - Replace Front Headlamp Assemblies
I needed to replace the front headlamp assemblies currently installed in my 2014 Chevy Caprice PPV.
The front lenses were so bad that the amount of light emitted by the headlight bulbs is being greatly reduced by the poor quality headlamp lenses.
https://www.youtube.com/watch?v=4GGefDJHm54
2014 Chevy Caprice PPV - Replace Front Fender Liners
My 2014 Chevy Caprice's front fender liners needed to be replaced.
I purchased some aftermarket fender liner replacements mainly targeted for the 2008-2009 Pontiac G8.
They worked out quite well after some reshaping of the foam filler piece on the passenger side.
https://www.youtube.com/watch?v=KuEBQDK-0qg
Re: 2014 Caprice PPV - YouTube Project Car
Where did you find the cheapest place was to order the OEM headlights?
