2014-2017 Paddle Shift Wheel Instructions
bearcatfan78
Post by bearcatfan78 » Tue Apr 20, 2021 7:42 pm
Something I've been wanting to do for a while now was share the installation instruction for installing a paddle wheel that I send out with my wiring kits.
I sell the premade kits for $30 shipped, with all parts required to install and a hard copy of the instructions below. Email me at williamatolbert@gmail.com FMI and purchase.
This is ONLY for 2014-2017 cars that want to add a 14-17 SS Sedan or 10-15 Camaro paddle shift wheel. Other wheels with paddles may work, but the SS and Camaro are the only ones that have been tested.
Wanna build your own? Parts and tools list is as follows.
Parts required:
  • Clock spring connector - Mouser # 306-SAIT-A02T-M064
  • BCM connector - Mouser # 306-SNAC3-A001TM0.64
  • Toggle switch - Mouser # 612-RR511D1121
  • 10'-12' of 20-22 AWG stranded copper wiring
  • 2 (two) 22-16 Gauge Female Spade Connector (available on Amazon)
Tools required:
  • Molex Crimping Tool - IWISS SN-28B (available on Amazon)
  • Terminal Crimping Tool - Haisstronica Crimping Tool for Insulated Electrical Wire Connectors-AWG 22-10 (available on Amazon)
2015 Chevy Caprice - Heron White
Former South Dakota Highway Patrol Car
Full Holden Conversion
https://www.holley.com/garage/view/7279 ... t-caprice/
Re: 2014-2017 Paddle Shift Wheel Instructions
Post by smwalker » Wed Apr 21, 2021 1:21 am
Just to make a note on this. This approach is taking the paddle wheel inputs and putting them in the BCM spot that the shifter is supposed to use. If you are not installing an SS shifter that is fine.
If one plans to install an SS shifter can the Paddles and the shifter coexist using the same BCM spot? I suppose maybe they could if you have the on off switch. Or maybe just do not use the tap up tap down on the shifter??
Tony ever heard of anyone doubling up the paddles and the shifter into X2 Spot 11??
Post by s/c'd cav » Sat Apr 24, 2021 6:19 am
nice , one of these years ill be tearing into mine
JUNKYARD_JACK
Post by JUNKYARD_JACK » Thu May 20, 2021 5:53 pm
Does our airbag transfer over? For example would something like this work?
https://offerup.com/item/detail/1203122 ... MARO+WHEEL
impalaplt
Post by impalaplt » Thu Sep 09, 2021 8:13 am
Parts required:
Tools required:
Are you still selling this kit?
I've tried email, but haven't got a response....
