Help Door Locks
Posted: Mon Nov 11, 2019 7:21 pm
by bluethunder
I don't have a manual and was wondering how to stop the doors from locking all around when the car is put in gear. Thanks.
Re: Help Door Locks
Posted: Mon Nov 11, 2019 7:25 pm
by Fudgehog
This is done in the customize options menu on the DIC. Right above the steering wheel, hit the Source button a few times until customize options shows up and then hit the right angle arrow scroll wheel to enter it.
It's pretty simple really. Car must be in park.
Re: Help Door Locks
Posted: Mon Nov 11, 2019 7:41 pm
by bluethunder
thank you
Re: Help Door Locks
Posted: Tue Nov 12, 2019 3:06 am
Depends on the year I think. 14+ it's controlled in the radio I believe
Re: Help Door Locks
Posted: Mon Jan 06, 2020 7:56 pm
by bluethunder
My recent PPV 2013 has non operable rear windows, and yes the connection under the front passenger seat is connected. Maybe they pulled a fuse. So the question is do the rear windows have there own fuse and if so can you point me in the general area under the hood or the left side kick panel. ? Thanks
Re: Help Door Locks
Posted: Mon Jan 06, 2020 10:52 pm
by Mooseman
Did they ever work since you've had it? If not, maybe the PD disconnected the switches in the doors.
Re: Help Door Locks
Posted: Tue Jan 07, 2020 2:49 am
No they do not. They share a circuit breaker withe the front windows. SO if the fronts are working the rear should be getting the power the need.
http://i.imgur.com/1zFGSEu.png
Re: Help Door Locks
Posted: Tue Jan 07, 2020 5:22 pm
by cerbomark
smwalker wrote: ↑Tue Nov 12, 2019 3:06 am
Correct.
Re: Help Door Locks
Posted: Wed Jan 08, 2020 10:06 am
by bluethunder
My fronts work fine and the rears are plugged in, I have had the rear door panels off to check them .
Thanks for the reply
Re: Help Door Locks
Posted: Wed Jan 08, 2020 12:03 pm
by shawnjon82
If you’re able to solve it please take pics and post as to help others in the future with the same issue thanks
