Page 5 of 6
Re: Installing factory rear vision camera on 2014
Posted: Mon Dec 09, 2019 10:05 pm
by smokin14ppv
smwalker wrote: ↑Fri Nov 15, 2019 9:26 am
Can build in a day. Have all the stuff for like 3 of them.
any supplies to build another? interested
Posted: Fri Dec 13, 2019 9:49 pm
smokin14ppv wrote: ↑Mon Dec 09, 2019 10:05 pm
I have stocked up and ready to make them up. Cost is $75.00 - Paypal (Friends and family) or Zelle to
PPVSteve@Gmail.com - Let me know your shipping address and what year you are installing into. 14+ get the terminals for the X4 radio plug. 11-13 get an RCA male end.
Posted: Sat Dec 14, 2019 12:23 am
by WildGS
Posted: Mon Feb 24, 2020 3:11 pm
by Godssondp
Very Great write-up. Curious about differences in the deck lids between the years 2011 and 2015. Between my friend and I, we own a 2011,2012 and a 2013. Could we use the factory 2015 camera and trim on any of these or can we make it work? Looks like we just need to cut the square hole for the camera and drill the 2 mounting holes on each side. Thanks in advance for any info.
Posted: Mon Feb 24, 2020 11:39 pm
by Pursuit
You just remove the key lock assembly from the trim garnish and install the camera there. The lock assembly is dimensionally the same as the camera. You will need to remove the trim garnish across the back of the trunk. I did buy a 2015 trim garnish to use with the camera. Not for sure but the original trim garnish may work. Keep in mind that you will lose the ability to unlock the trunk manually. I already had a fold down center section where I could pull the emergency trunk release.
Posted: Tue Feb 25, 2020 1:13 am
by WildGS
camera should pop in any factory trim, no modifications needed
Posted: Mon Mar 09, 2020 6:44 pm
Update to a part number for this project - Maybe. Someone looking for the camera at various sites today noticed one site said the camera part number had been replaced by 92288994 - None of the sites had any vehicle fitment information but then again they did not have much for the original part number for the camera. I looked around and found the part number to be used on the 11-13 middle east caprices. Now why a part number from 11-13 would replace a part number for a 2015 model part is beyond me. Still need to find out if the harness that connects to it is the same and if the connector and wires are all the same . Only reason I mention it now is it's $100 less so if you are on the cusp of buying may want to wait till we find out whats up.
Will update with findings.
- Middle East Caprice Camera Listing
- Screenshot 2020-03-09 at 3.35.37 PM.png (597.65 KiB) Viewed 8172 times
Posted: Tue Aug 11, 2020 1:45 am
Just a FYI and a heads up - Got this from another member:
I received the cameras, I ordered from GM out of TX the better 2247 camera for $119 and received the 8994. kinda pisses me off because another dealer had the 8994 for $91. So Ill let you know how it goes. It must be an automatic replacement part #.
Looks like GM playing fast and loose with part numbers!
Posted: Tue Aug 11, 2020 11:20 am
the GM parts catalog used to show 2 different part #'s , now it only lists the one # 92292247
Posted: Sun Aug 16, 2020 5:35 pm
s/c'd cav wrote: ↑Tue Aug 11, 2020 11:20 am
Could you also check 92288951 the lid harness, just got word that might be discontinued. See any stock anywhere? I need to get my hands on one to copy if discontinued.
Of if anyone has one that you have not installed yet break out the camera and tape measure!!
