Front Wheel Wells
Front Wheel Wells
Does anyone know if the G8 and PPV wheel well liners are the same or close enough? Mine are shot to bits (along with the undertray), and as a result the bumper is much less solid than it should be. G8 well liners are like $12 each, and I suspect are similar.
2011 PPV 9C1 "Blue Two" (150k+ miles, stock)
1989 Chevy 2500 "Black Bertha" (330k+ miles, needs motor)
1993 Mercedes Benz 190e 2.6LE "Black Bandit". 1 of 700 ever made, needs Transmission and frame
1986 Mercedes Benz 190e 2.3 "Creampuff. Frame and Trans for Bandit, but too fun to gut (yet).
A never ending stream of bad luck with cars...
- Administration Staff
Re: Front Wheel Wells
not sure where you sourced that info.....G8 & all PPV's used the same liners, left & right, and they aren't $12
92270537 & 92270538
https://www.gmpartsdirect.com/oem-parts ... r-92270538
The lower deflector (what you called undertray) is an essential part to provide integrity and support for the entire front fascia/bumper cover.
https://www.gmpartsdirect.com/oem-parts ... r-92247388 (same for all years PPV)
92270537 & 92270538
