Anyone install a REAL GM LSX block on a 2014 Caprice, I have a few Questions.
Turbopowered68
Post by Turbopowered68 »
I will most likely be getting my hands on a built LSX block- 427 W/TF245 heads.
Anyways my concern is the Added weight on the stock shocks and springs.
What did you guys upgrade to (suspension wise) when you went to the heavier iron blocks?
2014 Caprice V8
1986 GN
1968 Chevelle
Groundczero
Re: Anyone install a REAL GM LSX block on a 2014 Caprice, I have a few Questions.
Post by Groundczero »
Have not done it on the PPV but did it in my 85 mustang, when from a stock ls6 to an iron 408.
I did not change a thing it was only like a 40lb difference, if you are still on the stock ppv springs they are already rated for extra weight due to all the cop stuff so would not worry.
kevink
Post by kevink »
You'll be fine. Don't worry about it. The factory ride height is way too high anyway. People add LSAs, turbos, and centrifugal superchargers all the time and it's never a problem.
Sanford
Post by Sanford »
As Kevin said, don’t worry about it. Considering there is probably 20 lbs of siren speakers and 50 lbs of push bar that are no longer hanging in front of the axle, the extra block weight behind the axle should not matter.
David
Turbopowered68
thanks for the replies.
We are still working on the details
Wish me luck
2014 Caprice V8
1986 GN
1968 Chevelle
