Spongy Pedal after Brembo update
Fudgehog
Re: Spongy Pedal after Brembo update
Post by Fudgehog » Wed Oct 30, 2019 12:24 am
Try bleeding them once or twice in the order I posted. Trust me. I had to bleed multiple times to get the firmness close to stock.
03 Silveraydo 4.8L
13 Caprice 6.0L, Solo catback exhaust, 3.27 diff, VCM OTR
johnpz2721
Post by johnpz2721 » Wed Oct 30, 2019 1:29 am
Thanks I only did the front. These Brembos only have 1 bleed screw on the outside of the caliper these are massive as they have to stop a 700HP Camaro they came off maybe there is an air bubble on the inter section of the caliper
Fudgehog
Post by Fudgehog » Wed Oct 30, 2019 1:35 am
One bleed screw? Interesting..
03 Silveraydo 4.8L
johnpz2721
Post by johnpz2721 » Wed Oct 30, 2019 1:54 am
The Regular SS calipers have 2 and a crossover pipe this set has no pipe and 1 bleed screw I think even the pads look different ?
Fudgehog
Post by Fudgehog » Wed Oct 30, 2019 1:55 am
I would definitely try back to front starting with right rear, left, front right and front left.
It's most likely a bleed issue.
03 Silveraydo 4.8L
Post by Navy Lifer » Wed Oct 30, 2019 2:43 am
Take another look.....these are the Gen6 Camaro (Alpha) calipers running on the PPV 345mm rotors. There is no external fluid transfer pipe, true, but there are definitely 2 bleeders on each caliper.
https://www.rockauto.com/info/1/A1_185481_Top__ra_p.jpg
Pads are the same spec as on SS sedan (with earlier caliper configuration) - D1474A, with the small pad dampers, which may not clear OE 18" steel wheels.
johnpz2721
Post by johnpz2721 » Wed Oct 30, 2019 2:49 am
The ones I have are much beefeyer than those I wonder how they got them they make 700 and 900
HP versions of there Camaro
Post by Navy Lifer » Wed Oct 30, 2019 2:52 am
Photos?
How many pistons?
What rotors?
johnpz2721
Post by johnpz2721 » Wed Oct 30, 2019 2:56 am
4 pistons Stock Rotors
johnpz2721
Post by johnpz2721 » Wed Oct 30, 2019 3:02 am
Here’s a pic
