Manifold Absolute Pressure Sensor???
I am getting trouble code P0107 Manifold Absolute Pressure Sensor fault. Could someone direct to were this sensor is located so I can inspect it. I just put my engine back together after changing some lifters, I think this is was is causing my Stabilitrak fault to keep coming up.
Re: Manifold Absolute Pressure Sensor???
Wild I’m getting the same thing but I replaced my map sensor twice it’s on the top front left in the engine right underneath that dumb hose that sits on the engine I am getting the stability issue as well I know this is from years ago did you ever find the fix ?
