90psi Oil pressure??
markf1971
Re: 90psi Oil pressure??
Post by markf1971 »
s/c'd cav wrote: Fri Jan 06, 2023 10:08 am thats the DOD connector
Can you disconnect this connector that was identified (top picture in #4 post) and the DOD be 'disabled'? As in, like the same manner as disconnecting the connector to the sensor on the power brake booster (thanks Mooseman!), or using a Range device on the OBD2 port?
If so, do you know what if any codes will be thrown?
Thanks!
markf1971 wrote: Sun Feb 19, 2023 5:38 pm
Thanks!
not if you want the engine to run correctly , the DOD system is alot more involved than just the VLM !
disconeccting the vac sensor in the booster creats a CEL code , and the computer knows to not turn the DOD on , which is why others will use it , plus its easy to get to
