ROOF RADIO ANTENNA MOUNT AND MAST
I need the factory radio antenna mount on the roof.
Re: ROOF RADIO ANTENNA MOUNT AND MAST
What year of car do you have?
It’s 2013, but they are all
the same which is good.
the base on the 11 is a 1 year part # , 12-13 are the same # , 14-17 are the same
the mast is 11-13 , then 14-17
so they are not all the same
Thank you for clarifying. I stand corrected. I actually won’t be needing the parts. My radio works fine without it which is odd. I noticed the radio antenna is attached to rear window.
that was done by the upfitter , ive seen a few like that , they use the stock antenna for their gear
Your absolutely right. The shark fin replacement on my roof has cut wires with gps, 5G, etc labeled on them so you are correct. Glad at least radio is operative.
i did forget to mention the rear glass is the OE with the antenna in it , its just not used normally
Any idea what the part number is for the replacement mast for a 2011? Of course I have one that was built in the first half of the year, making it even more difficult as far as parts go
