Front ABS Fault
Hurricane2
Front ABS Fault
Post by Hurricane2 »
I took my car to a mechanic and they are saying the ABS wiring harness connector is loose. They want to replace the wiring harness in the front right wheel.
The part number for the front is GM Original Equipment 92211235. This seem to be out of stock or obsolete. Will I have to pull it from another car or is there another part number a newer one floating around?
Re: Front ABS Fault
it was used on the G8 and 11-13 caprice , alot depends on what they mean by loose ?
this is the part # 88988136 , for a service connector which would plug into the sensor on the bearing , if that is the end that you need
Hurricane2
Re: Front ABS Fault
Sorry to bump and old topic but I had to buy some from Australia. I got two just in case.
Sanford
Re: Front ABS Fault
Post by Sanford »
Hate to think of how many have gone to the scrap metal yards. Watched a 11-13 get crushed at a salvage yard that had all kinds of goodies on it.
