O rings
Car54
O rings
Post by Car54 »
Doing the afm delete on my car.
Took out the radiator and condensor.
Drivers side BOTH connections for the AC lines that go to the top and bottom of the AC condensor.
????Anyone know the part #’s for the o rings to those fittings top & bottom???
One is larger than the other visually.
Sanford
Re: O rings
Post by Sanford »
I was able to match the ones I needed at my local NAPA.
JoeR
Re: O rings
Post by JoeR »
As Sanford says, your local parts store will have an assortment on hand. Take them off and bring them with you. If not, you can usually buy a bog of AC o-rings for doing R-134a retrofits for pretty cheap. That should have the size you need in there.
Joe
Car54
Re: O rings
Post by Car54 »
Thanks all was able to get em from Advanced auto this afternoon.
Appreciate it
