Rear Door
Supposedly the speakers are behind the door panel in the 9C1 cars. I could not locate pictures, but I will pull my door panel, confirm, then reply with pictures.
The solution that I have read on the forum is to relocate the speaker, cut a hole in the door panel, then add aftermarket speakers grilles. Some look good, some look bad.
My proposed solution: Cut a hole in the door panel, add a custom 3D printed grille cover that looks more stock.
After I investigate the space available on my door panel I plan on attempting to design and print a grille cover solution.
Rear Deck
Based on my car and what I have read in this forum, the 2014+ 9C1 cars do not have rear deck speakers. I have read about using SS rear deck speaker grilles, but have not located any pictures of this solution implemented on the Caprice.
My proposed solution: Knock out the sheet metal in the rear deck and add SS speaker grilles.
Questions:
- Is GM 92267677 the correct part number for both left and right rear deck grilles?
- How do I attach the grilles to the deck?
- How do I attach the speaker to the grille?
- How would I wire the rear deck speakers... Splice off of the rear door speakers?
