2014 Caprice not conventional build
Re: 2014 Caprice not conventional build
I have been chipping away at it little by little
Car sill needs work on--
Replacing the OE torque converter with a new ZL1 converter
While replacing the torque converter I'll also be adding a dip stick, Camaro trans pan and filter
Will also be replacing the motor mounts with the " Technico Torque Master billet mounts"
Flickering exterior and dome lights
Drivers door panel has some damage - Not sure what I am going to do
A-Pillar spot light needs to be gone
Trunk and roof have a few holes that need fixing.
NEED to replace both front strut bearings
already Done
Installed Trunk lid liner -- Done
Paint work- temporally done
Driver seat swapped - Done
Fender vents = just ordered hopefully on their wayDone
Spare tire and jack set Done
Windshield washer line fixed Done
Wheels replaced - I hate them steel wheels = I have a lead on some 18 inch Camaro wheels-hopefully it works out. Done
Console needs some work Almost Done
Need to figure out the rear door lock-unlock mechanism. Done
Need to figure out the Bluetooth on the radio. Done
The horn -- Done
already Done
The horn -- Done
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Not seeing any pictures, so it's obvious none of this really happened, amiright?!!Turbopowered68 wrote: ↑Tue Apr 06, 2021 6:40 am I have been chipping away at it little by little
already Done
The horn -- Done
I am normally a picture whore but I've been slacking latelyCrashTestDummy wrote: ↑Fri Apr 09, 2021 9:46 am Not seeing any pictures, so it's obvious none of this really happened, amiright?!!
I'll get some later and post them up.
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
ZL1 torque converter is IN
Deep Camaro pan is IN
Camaro trans filter is IN
Dip stick tube is IN
Billet motor mounts are IN
Home made torque strap is OUT
Exhaust manifold gaskets are in IN
I Need to sort out the tune as the car is bogging down in 5th and 6th when the converter locks up, I am going to try raising the lock up speed to see how that works. I really see not point in locking up in 6th gear and only going 45 mph. going to raise lock up on 6th to about 64 MPH especially since i have the lock up set to ZERO slip. Let me know what ZERO slip parameters you guys are running.
Next on the list
Just ordered swaybar end links.
Next on the list
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Which dipstick tube did you use? I hate not having one.
ACDelco GM Original Equipment 24260606
15796802 - SEAL - General Motors
24267668 - INDICATOR - General Motors
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
What kind of sway bar hardware are you using?
haven't gotten them yet
ordered
Dorman SL90472XL
Dorman SL90471XL
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Dang, you move fast. How was the converter install?
the job it self wasn't bad, but now having issues with engine, getting KR all the time even at VERY low part throttle not sure what it is or where its coming from, Tuner already looked at the tune and logs and said "its not the tune" so the hunt is on.
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
