Cylinder 2 misfire
TaMuKa
Cylinder 2 misfire
Post by TaMuKa »
Hello all, I’m new to this forum and have recently purchased a 2012 Caprice w/ the L77.
I’ve researched my issue up and down and found similar problems but not exact so I thought I’d try and get some advice or hear from someone who has experienced something similar.
When i bought my caprice it had a misfire on cylinder 2 that would throw a CEL (P0302) within minutes of idle.
I went the route of replacing all the spark plugs (old ones were pretty dirty) and wires, the ignition coil for cylinder 2, and the harmonic balancer (it was wobbling).
The misfire is still there but it throws a CEL more rarely and it seems to drive just fine. You can definitely feel and hear the misfire at idle.
From what I’ve read cylinder 2 does not have the DoD and I don’t hear any ticking, but I’m really at a loss right now.
Any advice would be much appreciated. Thank you.
lastcall190
Re: Cylinder 2 misfire
Post by lastcall190 »
Where reasonable, move ignition/fuel components from cylinder 2 to another, perhaps one without DOD. See if the code moves.
check the wiring for the coil and injector at cyl#2 , also swap the #2 injector with another one on that side and see if the missfire moves
TaMuKa
Post by TaMuKa »
Hey!
Thank you both for the advice. I will go give that a try and get back with the results.
Cheers
TaMuKa
Post by TaMuKa »
UPDATE: I switched the injector with a different cylinder and cleaned both of them up as they were both dirty around the gaskets. I then started it up and led it idle for 30min and it sounded better and did not throw a light. I took it for a drive and it felt better. However, I came back after a few hours and started it again and the CEL came back on after less than a minute of idle with the same misfire in cylinder 2 (P0302).
It honestly seems the CEL doesn’t appear once the engine is warmed up.
Anything else I should check before I go down the route of opening her up?
Do a compression test on all the cylinders and compare. Do it on a cold engine since it seems to be affected more when cold.
pull the valve cover and inspect the rockers and valve springs
TaMuKa
Post by TaMuKa »
I plan to check the compression and pull the valve covers this weekend. Thanks for the advice and I’ll update once I find out anything.
TaMuKa
Post by TaMuKa »
So I was able to pull the valve cover and watch the rockers. They all move in what looks like good order, except for the cylinder #2 rocker which looks to be moving slower than the rest.
Does that mean low compression?
Thank you for the help. I appreciate it.
not sure what you mean by slower , or how you are viewing them move
but if that means its not pushing the valve down as far , means the cam lobe is flatten down , which means do not drive and get the cam.lifters replaced , and hope the cam material didnt scratch up the bearings
