Media Cables, Harnesses, Plugs
Post your Caprice PPV parts & components for sale here.
Post by smwalker » Wed Jan 22, 2020 5:59 am
I have the following media cords and harnesses available for sale. Keep in mind most all of these cords need to have programming done to the head unit for the items to work.
See Chris White at www.whiteautoandmedia.com for programming services.
Send me a message /email if you need multiple items and I will give you a total for everything.
Payment: Paypal (Friends and Family please) or Zelle (most banks offer) to PPVSteve@Gmail.com
Include your shipping address in the notes.
Items usually ship the next day, tracking will be provided for all items.
WM Caprice PPV - 2011-2013
USB / 3.5mm Aux In Kit - This kit consists of 2 cords and an included GM receptacle (25832462). The receptacle will get mounted somewhere in your interior to your liking. Cords are about 5 feet long to reach many places. USB cord will get plugged into the drivers side of the radio. AUX in cord requires inserting 4 wires into the main radio plug.
COST: $65.00 Shipped - Unavailable
PRODUCT UPDATE: My supplier for GM part number 25832462 is out of stock and since it is a discontinued part will not likely have any more. These receptacles are still available on the market I just cannot get them at a good price any longer. Or if I can they are from China clone workshops and I am leery of quality. So I will leave that up to you to source the part for yourself and I will still make the cables that will work with it. So you can either search for 25832462 the black face one or 20870101 for the white face one.
COST FOR CABLES ONLY (without receptacle): $45.00 Shipped
20 Pin Video Input Connector - This connector will give you a standard female RCA connector for the rear camera video input and the DVD video input. NOTE: If you are adding a factory rear camera set up to a WM PPV this connector will be included with the camera harness. If you are adding an aftermarket backup camera then this connector will plug right into the standard RCA patch cord that usually comes with the aftermarket units.
COST: $35.00 Shipped
Factory Rear View Camera Harness - This harness is used when you are installing the Factory GM rear view camera from the 2015+ PPV. You will buy the Camera and the Trunk Harness from GM. This harness will continue on to the IQ radio and plug into the side with an included 20 pin video input connector.. It will get it's power from the AUX battery relay and turn on signal via a splice into the reverse light circuit in the trunk on the passenger side of the vehicle. (see below for similar picture)
COST: $90.00 Shipped
WN Caprice PPV - 2014 +
USB / 3.5mm Aux in kit - Similar receptacle to the kit above just with different terminals to be inserted into the Mylink radio connector and the factory installed USB plug in the harness of the center console. 2015+ Mylinks need programming for the AUX in to work.
COST: $50.00 Shipped - Unavailable
COST FOR CABLES ONLY (without receptacle): $35.00 Shipped
Factory Rear View Camera Harness - This harness is used when you are installing the Factory GM rear view camera from the 2015+ PPV. You will buy the Camera and the Trunk Harness from GM. This harness will continue on to the MyLink radio and you will need to insert 2 terminals into one of the radio plugs on the back of the unit. It will get it's power from the AUX battery relay and turn on signal via a splice into the reverse light circuit in the trunk on the passenger side of the vehicle. If you have removed your AUX battery tray and electronics I have an option for hat as well, let me know.
COST: $75.00 Shipped
After Market Camera Input Lead - Use this lead if you are installing an after market camera that uses a standard male RCA to send the camera signal. I can also send you a pigtail with the correct connectors to hook into the AUX battery circuit (at the isolator) if you would like to get the camera power from there. If you have removed your AUX battery tray and electronics I have an option for hat as well.
COST: $20
Other - Non Audio related Parts and Plugs
Repeater Harness - This is a set of connectors for the Australian and Chinese LED fender repeaters with about 9 foot of cord to attach to the headlight harness. Comes with standard connectors and adhesive shrink tubing for the 4 splices that need to be made.
COST: $25
Antenna Connectors - These are the correct Radiall R197.160.B18 Farka Antenna connectors that are prone to breaking on our 11-13 IQ units. There require soldering to the circuit board. Professional installation recommended.
COST: $15
9C1 to 9C3 Console Conversion Wiring Kit - This includes wires needed to hook up the tap shift when using a G8 or 9C3 Shifter. Also included is the wires needed to hook up a 9C3 switch for the trunk release / Traction Control button. Can also modify if you re using the Traction Control / Sport button from Australian models.
COST: $35
SS Shifter Conversion Harness - Still working out the kinks on this one. May also incorporate a harness for installing a HUD in the dash. Contact me for pricing and details.
Link to instructions will be provided and I will walk you through the install if needed.
bfg4wd
Re: Media Cables, Harnesses, Plugs
Post by bfg4wd » Wed Jan 22, 2020 11:06 pm
Two questions about the camera harness.
First the header says 14 +, but in the description you say 15+ which is it? ( I have a 14)
What if any has to be programmed for the camera to work?
Regards,
Ted
Post by smwalker » Thu Jan 23, 2020 3:45 am
The Camera parts come from a 15+ so they do not need my harness as it comes with a camera from the factory. So really the harness for the 14 is only needed on the 14. I was trying to think of an elegant way to say that and also imply that my harness can be used on the 11-13's using a 15+ camera. Think I failed! LOL
For the 11-13 and the 14 the silver radio box in the dash has to be programmed. Which means sending the entire box in to Chris. On the 14's Chris can also update the box to give you some other features and moving back up lines that is pretty neat.
Some discussion if it here: Installing Factory Rear Vision Camera on a 2014
GTPprix
Post by GTPprix » Mon Jan 27, 2020 5:54 pm
We have updated our products to link directly to this thread, thanks for Offering these Steve!!!! :D
Chris White
2017 Envision Premium II - Custom IPC/BCM/HMI
2018 Sierra Denali Ultimate - Custom IPC/BCM/HMI
2018 Jeep Trackhawk - Livernois Intake
getlikeme149
Post by getlikeme149 » Wed Feb 05, 2020 6:29 am
How do I go about buying the cable that’s $65
2013 CAPRICE PPV 9C3
Post by smwalker » Wed Feb 05, 2020 8:22 pm
Datcaprice
Post by Datcaprice » Thu Feb 27, 2020 3:35 pm
If I were to connect a DVD player, does the 3.5mm audio connect with the AUX in? Also, will I get backup camera, plus DVD options?
I still need to get the silver box flashed.
Post by smwalker » Thu Feb 27, 2020 10:16 pm
Once the silver box is programmed you will get
Audio AUX in - Via 3.5mm (or could be RCA's if you wish)
Rear Seat Entertanment - Video Input is via the 20 pin connector (that also gives you Backup Camera input) .
The Audio Channels come in via 3 spots on the main radio plug (separate from the Audio AUX in mentioned above)
Make sense? So really you get two audio AUX in's one is just tied to the onscreen video as well.
Holdenaddict
Post by Holdenaddict » Tue May 05, 2020 8:10 am
WM flashed my 2013 Caprice silver box. Now the camera feature comes on in reverse. What cable do I need to buy from you to connect an aftermarket camera? I can figure out the power source via a reverse light.
Thanks in advance,
Mike
Post by smwalker » Tue May 05, 2020 8:36 am
If it's a 13 chances are you do not have the 20 pin plug on your circuit board. So no harness/connector from me will work. You will be doing some soldering. I recently found this neat product that helps with soldering small wires. Link:
viewtopic.php?f=21&t=1250&p=29358&hilit ... 3e0#p29358
But take a look to see if you have the plug. It is below and to the front of the main radio plug. There might be a piece of white tape over the hole.
