Fuel Pump Access Under Back Seat?
CapriceOut
Post by CapriceOut »
Hey everyone, I don't want to drop the tank to install my new fuel pump, I want to cut out an access hole under the back seat. I've seen people talking about it, but not in enough detail. If anyone has information and/or pictures to help me figure out where I need to cut the hole, I'd greatly appreciate it!
2012 9C1 6.0, bolt-ons, DOD delete, cam, not running
1999 Trans Am, bolt-ons, 4.10 rear, 125 wet shot, lots of clutch system "upgrades"
1998 K1500 5.7, good tires
2000 CR-V, non vtak
Re: Fuel Pump Access Under Back Seat?
G8 guys been doing it for a while:
Cover Piece:
https://g8only.com/product/g8only-fuel- ... ess-panel/
CapriceOut
Thanks Steve!
2000 CR-V, non vtak
CapriceOut
Turn out the pump is fine, but the harness connector had a burnt terminal. I 'm replacing the harness tonight. Anyone have any experience with this? Can I lower the fuel tank without having to drop it completely?
2000 CR-V, non vtak
SSpeedracer
Post by SSpeedracer »
I replaced the harness through the same access hole I cut under the seat to replace the pump. Ensure you've got correct replacement harness, it's expensive and I could only find GM part, no aftermarket yet.
I'm traveling and can't load pictures, but I've got them all. Soon
SSpeedracer
Access panel cut, maybe 7in diameter
I used a dremel with cut off blades, harness is very close to underside of sheet metal, avoid cutting harness
2016 Caprice
SSpeedracer
Burned power connector
GM Replacement PN 13587174
back bag.jpg (164.63 KiB) Viewed 20209 times
2016 Caprice
SSpeedracer
New wire Gage (white) is thicker than old. I soldered with heat shrink instead of crimp.
wire gage.jpg (132.89 KiB) Viewed 20209 times
2016 Caprice
l_c_vo
Post by l_c_vo »
Does anyone have measurements as to where to cut? I need to take a peek at my pump. Not getting fuel.
SSpeedracer
Look at my pictures above.
2016 Caprice
