I found that cable and it looks like it's connected properly same color without anything extra. Fuse is also present. If l connect a multi meter at the fuse and press horn, should I see a voltage? Would this be a legit test?
What else can I look for? Is it possible that the actual 'speaker' whatever makes the noise is disconnected or missing altogether? Where is it located usually?
Horn Question 2013
Re: Horn Question 2013
The horns are located behind the bumper fascia, right next to the standby/parking light reflectors in the bumper. On each side. You should be able to access them decently by removing a few wheel liner screws on each side.
13 Caprice 6.0L, Solo catback exhaust, 3.27 diff, VCM OTR, MSD coils plugs wires, transmission pan upgrade.
