What is the FM antenna part # that should go here? Better yet, does anyone have one laying around?
I can't get reception on any FM station. I'd imagine it's because my antenna went missing at some point before I acquired the vehicle. I assume this is normally the FM antenna.
A picture is attached.
replacement FM antenna part number?
- fm.jpg (361.51 KiB) Viewed 10359 times
Re: replacement FM antenna part number?
I should have one around somewhere, I removed mine and used the array in the rear window, I'll look and see if I can find it
YOu ever do a write up on that? I like that Idea!indianajoe wrote: I removed mine and used the array in the rear window, I'll look and see if I can find it
I never did do a write up because i haven't verified the strength of it as an antenna (I don't really listen to the radio, ever) I also haven't grounded the shielding on the cable like the original antenna had.smwalker wrote:YOu ever do a write up on that? I like that Idea!indianajoe wrote: I removed mine and used the array in the rear window, I'll look and see if I can find it
it seems to pick up the big pop station well, but the radio alone could probably pick that up.
I do know that the short antenna i just installed on my corvette cant pick up any AM radio at all so that might be an issue too
AC Delco 13222572 looks to be the one. ABout $30. Or general fit aftermarkets for 1/2 that.
Thank you Indianajoe for sending me an antenna. This is now taken care of.
