overhead hole left by video system in 2013
can i assume an overhead console would get this hole filled? also, does anyone have the dimensions for the stock console so i know if one will fix my hole before spending the $120?
- Resized_20170929_150559.jpeg (140.86 KiB) Viewed 12711 times
Re: overhead hole left by video system in 2013
10.25" long , 7.75 wide
There is a plastic brace that is missing from there as well. THink it serves to stiffen up the area and provide something for the dome light assembly to mount into..
Thanks for the info.
Has anyone filled the hole left with anything other than a console?
You know if you need to fill up some more space maybe you could adapt a rear passenger DVD player to fit up there then send the DVD signal to some headrest monitors. Front passengers would control the DVD as opposed to how it was designed for the rear passengers to. But it would give you some dome lights up there:
http://www.ebay.com.au/itm/GENUINE-HOLD ... SwuAVWw451" onclick="window.open(this.href);return false;
It could also hook into the head unit after White does the programming. It using the GM LAN to control the DVD as well. that is pretty technical stuff but I bet you could get it working right.
smwalker wrote:There is a plastic brace that is missing from there as well. THink it serves to stiffen up the area and provide something for the dome light assembly to mount into..
Anyone know the part name or number I am after for the brace? I have the console coming....hole is slightly smaller than the console.
oh so the hole was not cut, thats good news. I am not seeing the brace as a seperate part, think it comes lightly glued to the headliner, There is a guy on Facebook right nor parting out a caprice, you on FB?centex2013 wrote:smwalker wrote:There is a plastic brace that is missing from there as well. THink it serves to stiffen up the area and provide something for the dome light assembly to mount into..
my measurements are edge to edge , forgot to mention that
so you are good to go once getting the roof mounted bracket
I put in a comment for you . Are you a member of the PPV owners and Fans group? If so this link should work. If it does not work join the Group:centex2013 wrote:I am on FB
https://www.facebook.com/groups/1463392 ... 22R9%22%7D" onclick="window.open(this.href);return false;
