Post your Caprice PPV parts & components for sale here.
CrashTestDummy wrote:Great, thanks. I'm looking to have a spare aux tray in case I need to replace the one I modded to fit the Odyssey battery I installed over there, and may modify the driver's side tray to fit another, if I feel the need to 'add lightness' again.
do you want just the tray, or the whole assembly wires term. and such?
I need to find tie brackets ...I keep moving parts as I remove them ...grrrr.
For starters, I need the glove compartment door and hood latch and all corresponding parts. The safety lever and release cable are there, but the agency must've cannibalized the actual latch. Let me know.
Thanks!
sorry no hood stuff yet. here's the glove-box, no gouges or major damage has the rubber insert and the plastic screw caps (one of each for sure, the other might be in my screw box?) I didn't clean, wipe or armor-all it ...its just the way I removed it and should clean up nice. $100 total shipped fedex only.
Sorry, been a busy weekend. The trays and the hold-down brackets and bolts. Thank you.
Thanks!
Looks good. Would you mind holding on to it for me until you can get the hood stuff?
2007 Saudi/UAE Caprice
2013 Camaro SS M6 "Panther"
I don't know how much i'll need for a front repair I need to do ? I looked the other day and the cable has some missing covering under the hood ...so do my other cars so I don't know if its made that way or another design flaw?
Passenger (right) taillight assemble if it has no scratches / damage.
Passenger (right) door lock / window switch and pigtail.
B pillar inside trim both sides (if it doesn't have holes from cage)
Spare radio silverbox to send Chris White
Where are you located? I'd be interested in the motor / trans / harness / ECU if your within 500 miles of CA/AZ/NV.
