Get 6
- Rewiredllc
Re: Get 6
Started working on the harness today. Got a new Gxp m6 harness. I'm gonna strip out the stuff that's caprice specific and add it to the Gxp harness. Lots of time spent looking over schematics and pin outs today.
- IMG_1618.JPG (55.92 KiB) Viewed 18395 times
- IMG_1617.JPG (59.34 KiB) Viewed 18395 times
Jim
7045302910 call/text/pm
@ncrewired
rewiredLLC
Doyouevenracebro?... Racing
@ncrewired
rewiredLLC
- Rewiredllc
Re: Get 6
I also ordered a ZR1 cam today. A nice improvement over the dod junk and will be great when the whipple arrives
Jim
@ncrewired
rewiredLLC
@ncrewired
rewiredLLC
- Rewiredllc
Re: Get 6
Harness workshop!
- IMG_1626.JPG (82.31 KiB) Viewed 18387 times
Jim
@ncrewired
rewiredLLC
@ncrewired
rewiredLLC
- Rewiredllc
Re: Get 6
Cooling fans added
- IMG_1635.JPG (94.04 KiB) Viewed 18384 times
- IMG_1634.JPG (82.53 KiB) Viewed 18384 times
Jim
@ncrewired
rewiredLLC
@ncrewired
rewiredLLC
- Rewiredllc
Re: Get 6
Seamless integration of Caprice and G8 GXP. Just finished not to bad really. Now I'll work on the car side.
- IMG_1639.JPG (62.2 KiB) Viewed 18358 times
Jim
@ncrewired
rewiredLLC
@ncrewired
rewiredLLC
- Rewiredllc
Re: Get 6
anyone looking for tech diagrams...
the ecu connectors are called x1 and x2
the fuse box connector is called underhood x1
and the car side connector is called x102
the cooling fan connector that needs to be worked is called x100
this will help when pulling the connector pin out views for the engine harness mods...
Jim
@ncrewired
rewiredLLC
@ncrewired
rewiredLLC
- Rewiredllc
Re: Get 6
Made some progress today. Got the BCM and the radio out and boxed up to send to Chris. I got my GXP shifter, I had read somewhere that it is different from the 5th gen Camaro shifter. I couldn't find anything different about them except where the handle goes and it makes no difference that I could see. Mocked up my brand new virgin never been fondled by another man GXP Shifter handle and knob. Sweet baby Jesus!!!!
- IMG_1754.JPG (79.51 KiB) Viewed 18321 times
- IMG_1752.JPG (57.69 KiB) Viewed 18321 times
- IMG_1751.JPG (60.08 KiB) Viewed 18321 times
Jim
@ncrewired
rewiredLLC
@ncrewired
rewiredLLC
- Rewiredllc
Re: Get 6
my caprice is a 2012. I found some differences today in the ecu wiring and the brake pedal switch. G8 and 2011 Caprice use a 3 wire switch. The 2012 uses a 6 wire switch and that goes to the BCM and the ECU. Funny the 3 to the ECU land exactly where the cpp switch needs to go, so I'll use the old style brake switch and re-purpose the other wiring to the cpp. The 2012 diagrams were incorrect, they said the cpp cavities in the ecu should still be empty like 2011. today's little nugget of Caprice love
Jim
@ncrewired
rewiredLLC
@ncrewired
rewiredLLC
Re: Get 6
Great thread, and thanks for all the info and updates.
- Rewiredllc
Re: Get 6
I got my BCM and Radio module back from Chris today. That was quick. Clutch pedal is in. I got all the mounts for the transmission also, everything seems to be correct. I'll share part numbers once everything is bolted together and 100%
Jim
@ncrewired
rewiredLLC
@ncrewired
rewiredLLC
