It is currently Fri Jul 20, 2018 11:29 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Fri Jun 20, 2014 3:16 am
Offline
System Manager
This letter may have been floating around for a while but this is the first I've seen it....
Quote:
2014 Caprice & 2015 Tahoe Spot Lamp - Strongly Recommend Factory Order
Recently, an issue has arisen that I want to make you aware of; 2014 Caprice and 2015 Tahoe have Ultra High Strength Steel (Boron) in the A pillar which make it very difficult to install a spot lamp. It is strongly recommended that dealers, upfitters and customers order the factory SEO option. Kerr Industries, who installs our spot lamps, had to work with Engineering to develop special parts, tools and process for these new vehicles. Kerr can be contacted for assistance if field installation is required. For Caprice, another alternative is to order spot lamp provision option 7X8 & 7X9 which provides the mounting brackets installed which is the difficulty with the Boron A pillar. Dealers, upfitters, customers then can install the lamp assembly, which will reduce their cost.
Silverado is the same situation and dealer / upfitter installation is going to be very difficult. There is a ship-thru from Silao to Kerr, but it is $475 which is cost prohibitive in most situations. We are working on SEO spot lamps for Silverado to support a 2015 Special Service Crew Cab package.
We are updating the order guide and technical manual to include this information. As mentioned Kerr Industries is the best source for assistance. Please ensure your dealers, customers and upfitters are aware of this situation.
Dana Hammer
Manager, Law Enforcement Vehicles
GM Fleet & Commercial Operations
There was some information in a sales Powerpoint a while back we ran across that the higher-strength steel was being used in the 2014 but this is the first I've seen it equating to installation issues. Very interesting....
_________________
System Manager and your tourguide for the day. Caprice Alumni, former owner of a 2011 Caprice 9C3 with a Rotofab CAI and front radiator cover, 3.45 LSD Camaro rear diff, Chris Henry performance tune, G8 GT 18" Enkei rims w/Holden lions, custom SLP axle-back muffler set with tips, Holden WM Caprice factory spoiler, Holden SSV leather steering wheel and leather shift knob, Whelen Alpha-12Q airhorn amp. G8 GT rear seat swap, AVS Ventshades.
Top
 Profile
PostPosted: Sat Jun 21, 2014 7:09 am
Offline
Kerr Industries installs the spot lamps as this is not done in the factory. From what I understand they have this super high dollar machine that drills the holes perfectly each time. I would guess it is like a big drill type press that has clamps that are perfectly molded to the pillar and door (for the cut out). It probably has some super expensive diamond drill bit as well.
Here is a view of the Arlington Texas Kerr Industries factory, this is about 2 miles from GM Tahoe/Yukon/Escalade plant.
http://www.youtube.com/watch?v=eBZl6Dbn7LM
Top
 Profile
PostPosted: Thu Jun 26, 2014 12:41 am
Offline
What does Kerr do to the Escalades? For the PPV, the up fitting is done in Benicia, CA which is about 40 miles from where I live.
Top
 Profile
PostPosted: Thu Jun 26, 2014 3:59 am
Offline
I believe Kerr installs advanced electronics like DVD player screens or livery packages. There is order code VPV, but does not give any details as to what it is, just that it ships to Kerr Industries.
VPV - HANDLING CHARGE ARLINGTON ASM TO KERR INDUSTRIES
Top
 Profile
Search for:
Jump to:
