2012 caprice lsa build, my quest for 10s in the family sedan
Maxspeed96ct
Post by Maxspeed96ct »
cars been done for a few weeks, but still need to upgrade the fuel system.
Basic mod list
-CNC ported LSA heads with btr springs, arp head bolts and ls9 head gaskets
- rcr PB blower cam 219/237 ...
-id850 injectors
-cx racing Heat exchanger, roush hx coolant tank in the pocket of the cabin filter area
-Zl1 lid with 12 an outlets and reinforced milled brick
-Air raid 5" intake with ls7 card maf
-Ported TB
-Lsa blower with slightly ported snout and 2.5" pulley
-kooks 1 7/8 headers
- custom self made ( not the prettiest ) 3" exhaust with two vibrant bullet resonators up front, two vibrant ultra quiets out back with a j-pipe. (Maybe adding a mid muffler soon cause its loud)
-Lsa coil packs and valve covers
-mishimoto catch can with an fittings
-Stock ss springs
-ZL1 / ctsv- converter with Camaro pan, also removed the thermostat from the factory trans cooler for more flow.
-3.27 Camaro diff
-2010 Camaro brembos all around using powerstop rotors from a 2016 ss sedan
at 88k both engine mounts and the trans mount needed to be replaced. Good idea to do them if your installing headers or doing exhaust work
Hp tuners Tuned by me
Car rolls out pretty good but tune is very soft due to lack of fuel, that upgrade will be happening in the next few weeks.
weld wheels 17x10 rear 18x8 front
Pics
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
ImageUntitled
Untitled
ImageUntitled
Combatcarl
Re: 2012 caprice lsa build, my quest for 10s in the family s
Post by Combatcarl »
Niiiiiiice. The LSA, any ppv specific issues that came up or is it all the same as the g8/SS Guys?
Maxspeed96ct
all pretty much the same as the g8 and ss
bluethunder
Post by bluethunder »
I think I have seen this car some place before.......Great job looks awesome!!!
B4CU
Post by B4CU »
I subscribed so hard. Great taste.
2013 White 9C1 Caprice
Silversled
Post by Silversled »
David,
Your car is looking awesome. Hope tuning is going well for you.
Could you give more info on the Welds for both front and back (model and offset) and the what tires you are running (Make, model, size)?
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
Black6
Post by Black6 »
Would the stock coil packs/valve covers not work with the blower?
Are you just going to do the boost a pump/pump controller re-flash?
Flex fuel? Please tell me flex fuel!!
Black 2014 V8
Black6 wrote:Would the stock coil packs/valve covers not work with the blower?
the coils need to move , either by using the LSA/9 valve covers , or moving them , they sit up to close to the sc and fuel rails
Silversled
Maybe Dave will chime in but he has since sold this car.
I believe he started with a reflashed fuel computer, then a DSX supplementary pump, then ended up with a full FORE return fuel system.
He and I exchanged some messages on dealing with Flex fuel. His fuel system retained the Flex sensor and I'm sure he got some of the tables updated before selling it.
2016 AMG C63
kras007
Post by kras007 »
What region of the country are you located? Hoping your in the tri state or New England area.
