It is currently Sat Oct 20, 2018 1:26 am
Post new topic Reply to topic  [ 13 posts ]  Go to page 1, 2  Next
Author Message
PostPosted: Tue Nov 07, 2017 2:40 pm
Offline
Looking for an aftermarket part number for the exhaust flange gasket by the muffler. Having difficulties locating them. Need something the local parts house can find or cross reference. Thanks!
Top
 Profile
PostPosted: Tue Nov 07, 2017 3:43 pm
Offline
https://www.gmpartsdirect.com/oem-parts ... xleA%3D%3D
This (current) part number has been updated from the original part.
Looking around, I can't find an aftermarket option for these gaskets. Unfortunately, for a low-production vehicle, the aftermarket doesn't always come up with a solution, which may be the case here.
_________________
Top
 Profile
PostPosted: Wed Nov 08, 2017 2:33 am
Offline
Navy Lifer wrote:
https://www.gmpartsdirect.com/oem-parts/gm-rear-muffler-gasket-92280995/?c=Zz1leGhhdXN0LXN5c3RlbSZzPWV4aGF1c3QtY29tcG9uZW50cyZpPUZSMDgyNjU1JnI9MTAmYT1jaGV2cm9sZXQmbz1jYXByaWNlJnk9MjAxMSZ0PXBwdiZlPTYtMGwtdjgtZmxleA%3D%3D
Thanks for the info! I might just buy some material and make my own and use some high temp silicone. Wont be a nice as oem but it will work.
Top
 Profile
PostPosted: Wed Nov 08, 2017 8:48 am
Offline
Depending on where you're located, most exhaust system shops will typically have a range of "universal" flange gaskets, and you might find something there.
Also found this--bound to be one that will be close enough!
http://www.walkerexhaust.com/assets/dow ... nChart.pdf
_________________
Top
 Profile
PostPosted: Thu Nov 09, 2017 5:02 am
Offline
Did some googling. Looks like the G8 guys are having the same problem. They either use rtv or universal flange gaskets. There are several brands to choose from. Might just buy a small tube of copper rtv and be done with it. I used that stuff before with great success.
Top
 Profile
PostPosted: Thu Nov 09, 2017 5:41 am
Offline
What am I missing here? The correct service part is available from GM, rather than the aftermarket...so how does that constitute a "problem"?
I understand the desire to avoid cost--is that the sole consideration?
_________________
Top
 Profile
PostPosted: Sat Nov 11, 2017 6:03 am
Offline
For me it’s convenience. I have multiple parts stores in my area that I can get to.
Top
 Profile
PostPosted: Sat Nov 11, 2017 11:27 pm
Offline
You've burned up 4 days already. Order the gasket online from GM. Better yet, order TWO sets so you're set for later mods. Just a thought.
I _have_ made gaskets from gasket material before, though, and been pretty lucky with it. It's a fair amount of work, though, with very sharp blades.
_________________
2010 Tahoe PPV (her car)
Top
 Profile
PostPosted: Sun Nov 12, 2017 6:52 am
Offline
Back home--measured the OE gasket 92280995
ID - 2.75"
Bolt hole spacing - 4.125" center-to-center
$11.85 (GM list price is $17.95 each)
Closest aftermarket gasket I can find:
Walker 31512
View here>>>> https://www.rockauto.com/en/moreinfo.ph ... 52&jsn=291
ID - 2-5/8" (2.625) - still larger than actual pipe ID
Bolt hole spacing - 4-1/4" center-to-center (4.250) - holes appear to be slightly oblong, so it should not be an issue to make this gasket fit the OE flange
$1.36 (via Rock Auto listing)
There now....does everyone feel better???
Who will now step up and spend the money to get this gasket and try it? I've done my part....
_________________
Top
 Profile
PostPosted: Thu Nov 16, 2017 3:01 am
Offline
Went to O’reillys and they easily crossed referenced the walker numbers to their nickson brand. A 13731-1 works just fine. I don’t see how I spend my time should be of any concern to anybody here. In this case I was more comfortable buying from the local store and that’s it. I ended up seeing somebody I know there and it was a pretty pleasant experience overall.
Top
 Profile
Search for:
Jump to:
