It is currently Tue Jul 17, 2018 6:05 pm
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4
Author Message
 Post subject: Re: 18" Camaro Wheels
PostPosted: Wed May 31, 2017 4:04 am
Offline
so the stock camaro wheel that come on these rims wont fit ? dam i just picked up a set mint with new tires from factory
Top
 Profile
PostPosted: Wed May 31, 2017 4:16 am
Offline
rims yes , tires no they are taller
Top
 Profile
PostPosted: Wed May 31, 2017 4:25 am
Offline
One of us is confused....
"so the stock camaro wheel that come on these rims wont fit"
Wheel = Rim
Camaro (2010-2015), G8, SS Sedan, and PPV are all the same (Zeta chassis)--offsets/widths vary by model, but bolt patterns and hubs are the same.
Depending on which wheel, there are going to be fitment issues for Camaro or G8 18" wheels on ANY Zeta car with Brembo brakes or conversion(s)--at least on the front. A small spacer might be all that is needed, however.
Not directly related to the topic, but the stock PPV steel wheel does clear Brembo front brakes (with D1001 pads).
_________________
Top
 Profile
PostPosted: Wed May 31, 2017 1:42 pm
Offline
that has got to be one of my biggest pet peves. There are wheels and tires, no rims.
_________________
Top
 Profile
PostPosted: Wed May 31, 2017 2:22 pm
Offline
not to belabor your point (and mine indirectly implied>>>inferred), a "RIM" is one of several parts that make up a complete WHEEL
(quoting from Tire Rack - link below)
What Is a Wheel and What Is a Rim? Are They the Same Thing?
It may seem obvious, but a wheel is comprised of a hub, spokes and rim. Sometimes these components will be one piece, sometimes two or three. The hub is the center portion of the wheel and is what attaches the wheel to the suspension. The spokes radiate out from the hub and attach to the rim. The rim is the outer part of the wheel that holds the tire. While many people refer to wheels as "rims," this is technically incorrect.
https://www.tirerack.com/wheels/tech/te ... ?techid=90
_________________
Top
 Profile
PostPosted: Sun Aug 27, 2017 3:02 am
Offline
Navy Lifer wrote:
OE take-off Camaro 18" wheels are hard to beat, too bad they're only 7.5" wide. I ran the first-design (2010-2012) 5th Gen 18's (5-spoke) for several years, and still have one as a spare.
I do have the 4 Camaro wheels that were on the ground and would consider selling them if anyone is interested. The tires--Continental DWS all-season in stock size--are still mounted, but pretty much worn out.
The new 2016 Camaro standard 18" (V6) wheel is 8.5" wide, but offset is 32mm, which puts the wheel almost too far out--but just the right width for a 255/45 tire.
They're a bit plain, but that just means there should be quite a few of them showing up as take-offs. Re-finished, they should look really good.
http://i62.tinypic.com/2qlsr4j.jpg
There are a number of other GM/Chevy wheels that will also fit--current FWD Impala & 2013-2015 Malibu have the same center bore, wheel stud pattern, and usable offsets. Just not sure about caliper clearance, especially for anyone thinking of doing a Brembo upgrade.
Top
 Profile
PostPosted: Sun Aug 27, 2017 3:09 am
Offline
Will the 2016 v6 Camaro 18 x 8.5 wheels clear the brake caliper on a 2011?
Top
 Profile
PostPosted: Sun Aug 27, 2017 4:57 am
Offline
yes--they'll clear stock brakes and they will even clear Brembo 4-piston calipers, with no spacers required.
If you're looking for some, I have a set of 4, new takeoffs
_________________
Top
 Profile
Search for:
Jump to:
