MMMMMM sidewall
- greasychevy
MMMMMM sidewall
15' wheels. hail mary 9 second(prolly not) pass comming soon, i hope.
- Fifteenssmall.jpg (269.82 KiB) Viewed 18517 times
2011 9c1 Hugo Blue
- greasychevy
- Raunchtastic
Re: MMMMMM sidewall
Get sum nawsss bro! 9s in a bottle!
Looks mean.
Looks mean.
- greasychevy
Re: MMMMMM sidewall
I think its going to come down to traction more than power. i go from 50-135 in about 8 seconds. spinning off the hit and a slipping blower belt losing 2-3psi. i figure a if i can 60 better than 1.6 should at least go 10.10s
2011 9c1 Hugo Blue
Re: MMMMMM sidewall
Car looks the business! Nicely done.
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
2016 AMG C63
Re: MMMMMM sidewall
What have you done as far as weight reduction?
Never-mind my post, I just read on the "carbon fiber hood" thread .
-Rob
2012 9C3 Mirage Glow Metallic
Re: MMMMMM sidewall
Car looks awesome!!!! love the stance
Re: MMMMMM sidewall
Did you have to change rotors, calipers, or caliper brackets to fit the 15" wheels or did they just bolt right on?
- greasychevy
Re: MMMMMM sidewall
had to change rotors, caliper brackets, lower control arms, and torque arms. also had to cut quarter panel liners, cut the bleed screw off the calipers, and bend over brake hose bracket and relocate hose. and grind the knuckle under the control arm mount. It was a pain.
2011 9c1 Hugo Blue
Re: MMMMMM sidewall
The joys of doing things that no one else does!greasychevy wrote:had to change rotors, caliper brackets, lower control arms, and torque arms. also had to cut quarter panel liners, cut the bleed screw off the calipers, and bend over brake hose bracket and relocate hose. and grind the knuckle under the control arm mount. It was a pain.
