Did anyone else decipher what the option codes on your SPID?
Re: Did anyone else decipher what the option codes on your S
Were would the SPID be?
I looked on the underside of my spare tire "cover" and didn't see it.
Thanks!
Tom Slick
Thanks!
Tom Slick
You have to look way under there, and it's upside down. You can, however, remove the whole cover from the car, it pulls out.
Bob Dannelley
2011 Alto Gray 9C3 Caprice PPV-Maggie-11.64@119.68-Sold!
1995 DCM Impala SS-409-Stroker!-11.83@115
2014 Silver Ice LTZ Silverado Crewcab 4X4
2007 Black Z51 M6-Corvette Coupe
If it was a snake, it would have bit me! was too dark to see it before...leadfart wrote:You have to look way under there, and it's upside down. You can, however, remove the whole cover from the car, it pulls out.
Here is a list of all my option codes:
AAW - Seats, Front Bucket
AH7 - Seat Adjuster, power front passenger 4 way
AKC - Airbags, Dual stage frontal thorax side-impact driver and front passenger w/passenger sensing system
AKP - Window type solar absorbing
AKX - Windshield type solar absorbing
AL5 - Sensor indicator inflatable frt pass presen detector
AQ9 - Seats, Front bucket
ATG - Remote keyless entry
AXJ - Passenger car
AX2 - Key common, vehicular unique
A6G - Seat Adjuster, power driver 8 way horixontal, driver
A98 - Trunk release, ignition control
BDR - Lock Cylinder RR compt
BIJ - Cluster Color inst
BW4 - Molding B/S (opel) extr, mldg, side window reveal, chrome
B34 - Floor mats, carpeted
B35 - Floor mats, rear
B42 - HEavy duty luggage compartment mat
CJ2 - Air Conditioning, dual zone climate control
CNZ - Module enhanced blower control
DD4 - Mirror, inside rear view with compass
DNS - Dealer installed indicator
DP2 - Dual power outside mirrirs control, electric, manual folding black
D72 - Door handles, black
EF7 - Country code, U.S.A. America (USA)
ESA - Plant Code
EVG - Equipment engine, V8
E2C - Order to Delivery - expedite
FCP - Door trim
FE9 - 50-state emissions
FGJ - Seat trim
FHS - Vehicle fuel gas E85
FLT - Fleet processing
GST - Mirage Glow Gold Metallic
GW8 - Rear axle, 2.92 ratio
G80 - Limited slip differential fully automatic
JL9 - Anti lock brake system, 4-wheel heavy duty disc
KD1 - Transmission oil cooling sys
K12 - Shift knob, urethane
KTB - Wireless PDIM *******************************************************************
KTZ - (NOT LISTED - Special police tune) ***
KW7 - High output generator boost
LHD - Left hand drive
L77 - Engine, 6.0L V8 E85 Capable w/ Limited Slip Differential. Replaces standard engine
MDC - Molding B/S upper bright
MX0 - Transmission, 6 spd automatic W/ tap shift
MYC - Transmission, 6 spd automatic
NT7 - Federal emissions system
NYD - Wheel, spare
N10 - Exhaust, dual tips
N40 - Power rack & pinion steering
N46 - Steering wheel, 4 spokes
RT3 - Wheel, 18" steel
R5M - All season tires, high speed XL 99 W BW AL3
R6A - FLT-ARI Identifier
R9N - Processing code-seat
TVU - Handling charge Elizabeth ASM to Kerr Industries, Benecia Port, CA
T3W - Daytime Running Lights
T4A - Headlamps, Halogen
T53 - Lamps, trunk lid, alternate flashing
UBW - AM/FM stereo with cd player & AM/FM stereo
UDC - Driver Information Center
UJ6 - Tire inflation monitor (excl spare tire)
UQF - Audio system, 4-speaker
U71 - Antenna roof, radio
VK3 - Front license plate bracket
VVQ - Calibration daytime running lamps
VZ3 - Label, mercury disposal
V8D - Vehicle statement US
WL9 - Model conversion
W2P - Full wheel covers
XL7 - Frequencies Rating 315MHZ, long distance
XR5 - Pollen filter
XW6 - Paint Finish
ZCZ - Spare Tire
02D - Seat Trim
1A6 - Door trim panel
1SC - Option package 03
1SZ - Option package discount
4BB - Jet Black
6J1 - Wiring-ignition & main power
6J3 - Wiring - grille lamps & speaker
6J4 - Wiring, horns/sirens circuit
6J7 - Flasher system tail lamp
7B3 - 4 wheel independent hd police suspension
9C3 - Unmarked police package
