picked up 2016
Silversled
Re: picked up 2016
Post by Silversled »
Car is clean! Congrats. Just little details to fix but car is good! Congrats.
2014 Chevrolet Caprice PPV
2014 Chevrolet Stingray Z51
2016 AMG C63
2015 BMW X5 iDrive 50i
cerbomark
Re: picked up 2016
Post by cerbomark »
Thanks, How do I get the rear seat bottom back in place? Can t get that front hook on one side back in, seems like front hooks have too much angle ??
BTW, cars has remote start!
2016 C1
lastcall190
Re: picked up 2016
Post by lastcall190 »
Mine required a little bit of tilting to slide it far enough under the seat back, but also to make sure all the belt buckles went through the appropriate slots.
Don't make the mistake I did and do it when it was in the single digits, busted one of the plastic clips which for some reason are oddly expensive.
cerbomark
Re: picked up 2016
Post by cerbomark »
lastcall190 wrote:Mine required a little bit of tilting to slide it far enough under the seat back, but also to make sure all the belt buckles went through the appropriate slots.
so maybe those rear tabs need to be under first before attempting the front hook?
2016 C1
lastcall190
Re: picked up 2016
I am having trouble visualizing it right now but I absolutely put the rear most part of the seat bottom in first, then pushed down the front into place.
cerbomark
Re: picked up 2016
Post by cerbomark »
lastcall190 wrote:I am having trouble visualizing it right now but I absolutely put the rear most part of the seat bottom in first, then pushed down the front into place.
Sorry I just posted on other section but at what angle does the front hook sit at? Up and down, or heavy angle back? Thinking someone may have bent it and don't want to bend it back until confirmed. Thanks.
2016 C1
Re: picked up 2016
should be up and down
cerbomark
Re: picked up 2016
Post by cerbomark »
s/c'd cav wrote:should be up and down
Thanks, so I assume it bent. going back at 45 degree angle.
2016 C1
No Moa
Re: picked up 2016
Post by No Moa »
With the camera above the plate, do you have one in the trunk lid? That is a neat place for one. I might have to look into it for my 14.
Also, you spot under the heater controls, something is missing, my has a pocket with a 12v socket In it.
2014 Caprice PPV silver
2017 Ram 3500
2002 CETA trans am
1995 9c1
1977 Trans am SE 4spd.
1978 trans am 400 4 spd.
cerbomark
Re: picked up 2016
Post by cerbomark »
No Moa wrote:With the camera above the plate, do you have one in the trunk lid? That is a neat place for one. I might have to look into it for my 14.
Yes have the trunk lid camera. Yes I have the 12v outlet.
Yes I am missing (it was cut) the lower control cover. I just covered he center console and added cup and junk holder. It s only a daily driver.Image
2016 C1
