88958753
LS Hot Cam
Duration @ .050" Lift (deg): I: 219 / E: 228
Maximum Lift (in) w/1.7 rocker**: I: .525 / E: .525
Lobe Separation (deg): 112
Relatively "mild" factory cam -- still provides nice increase over stock (L77) or even LS3 cam (430 HP in 6.2L)
GM crate LS3 with Hot Cam: https://www.chevrolet.com/performance/c ... /ls376-480" onclick="window.open(this.href);return false;
Quote from Chevy Performance online catalog:
"The LS3 delivers a stunning 495 horsepower and 473 lb.-ft. of torque. That’s nearly 14 percent more power and torque. The key to the power boost is the Hot Cam’s 0.525-inch lift on both the intake and exhaust sides, along with 219-degree/228-degree duration specs.
That’s less lift on the intake side than the stock LS3 cam, but considerably more duration, allowing the valves to stay open longer to draw in more air from the rectangular-port L92-style heads."
Requires valve spring upgrade & tuning for best results.
OE spring (blue) for use with this camshaft - 12625033
Current NEW price $609.62 >>> $579.14
https://www.gmpartsdirect.com/oem-parts ... t-88958753" onclick="window.open(this.href);return false;
$325 delivered - will post picture(s) here, or send to anyone requesting.
GM LS Hot Cam - new in box
Re: GM LS Hot Cam - new in box
Hi Bill,
Sent a PM. Not sure if if went through, it's still in my outbox.
2007 Saudi/UAE Caprice
2013 Camaro SS M6 "Panther"
Any idea what the idle quality is with that cam?
https://www.youtube.com/watch?v=o0T6hc60Uew" onclick="window.open(this.href);return false;
Try that.
Try that.
Not too bad. I little lope. I wonder the looks on driver's faces if the Caprice was at a light with a lope like that?
cam is currently spoken for, any change and I'll let you know.
