1/4 mile with Mod List
First Time at the track with my Caprice PPV:
1.73 60'
7.85 @ 88.1 1/8
12.32 @ 110.7 1/4
155K mile short block and transmission - PPV Steel Rims
Camshaft TSP Stage 1 LS3 N/A Camshaft 225/236 .629"/615" 114 LSA, 109 ICL
Texas Speed and Performance CNC Porting and CNC Valve Job of # 823 factory heads
TSP DOD Delete
Camaro 6L80 deep transmission pan and wide mouth filter
Torque Converter - Precision Industries 3600
3.27 Limited Slip Differential
Kooks Headers, No catalytic converters, 2.5” SOLO exhaust
Roto Fab Cold Air Intake
Hoosier DOT Drag Radial Tires 245/40-18
PB1117SS - PowerBond Race Performance Harmonic Balancer
1.73 60'
7.85 @ 88.1 1/8
12.32 @ 110.7 1/4
TSP DOD Delete
Re: 1/4 mile with Mod List
Update - Improvement
Charles Barber tweaked, thanks sir !
Increased tire air pressure to 26
1.68 60'
7.73 @ 88.9 1/8
12.13 @ 112.7 1/4
1.68 60'
7.73 @ 88.9 1/8
12.13 @ 112.7 1/4
Nice work. You can probably knock off a tenth or two with skinnies.
You can probably knock at least half a tenth going with a wheel that's NOT the Caprice wheel. Those things are heavy, and going with even a different steel wheel will cut some rotating mass. Aluminum would be even better.
BADASS
2014 Caprice V8
1986 GN
1968 Chevelle
1986 GN
1968 Chevelle
Personal best last weekend at Cleetus and cars Indy
Tsp stage 1 LS3 cam
Circle d 3400 converter
Solo exhaust and jba long tubes
Camaro 3.27 diff
Hoosier dr2 drag radials
100 HP wet nitrous shot out of the hole
Tsp stage 1 LS3 cam
Camaro 3.27 diff
- IMG_20230503_214025.jpg (5.03 MiB) Viewed 2336 times
- IMG_20230503_190916.jpg (6.22 MiB) Viewed 2336 times
- IMG_20230506_143750.jpg (4.48 MiB) Viewed 2336 times
2014 Caprice
Tsp LS3 stage 1 cam
3400 circle D converter
3.27 Camaro diff
Hoosier dr2 drag radials.
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
[nturl]https://youtube.com/shorts/a8r-gCzzASw?feature=share[/nturl]
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Great times Nate. How does all that grunt translate in terms of drivability? Does it feel good stoplight to stoplight?
It's pretty good stoplight to stoplight. I need to have my tuner adjust some stuff around 45-50 mph but other than that it's pretty normal just bucks a little bit at that one speed range.
2014 Caprice
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
Tsp LS3 stage 1 cam
3.27 Camaro diff
11.86 at 117mph
