2013 PPV on auction
Listings acceptable to post in this section are Caprice PPV's for sale by individuals, government entities (I.E. direct sale/auction/sealed bids), and the occasional car for sale on dealer lots (trade-in's for example) that do not normally sell Caprices. EBAY/Craigslist/auction site ads are OK for the above as well. Please do not post third party ads for cars on behalf of dealers that routinely sell used PPV's as part of their primary business. Listings by members with under five forum posts may be removed without notice, please check with a moderator if you have questions. SPECIAL NOTE - We have no role or liability in any transactions other then to provide a venue to advertise the items. Disputes must be resolved independently between the parties involved in any transaction.
Re: 2013 PPV on auction
I mentioned the idle hours because there are some agencies that will change the oil at xxx miles, which would usually be a reasonable number if it weren't for a bunch of idle hours that the cars get. Sometimes they don't check the oil often enough between changes either. If you have an engine that is a an oil consumer (which these certainly can be), they get run low on oil and bam, you've got a rod knock. I'd say that or an overheat (for whatever reason) are the 2 most common ways a lower-mile police car engine dies an early death.
-Brandon
Heh, yep. The idle hours on our '12 is ~50% of the total.
With AFM, the lifters can fail, too, which can do these things in. Our car got a cam replacement at about 50K miles.
I was going to mention that, too...but if a lifter collapses, it will still run...just not very well. I was thinking more catastrophic. But yes, sometime in the future I plan to cam mine, if only because I'll have it most of the way apart anyway to pull out those lifters and throw them in the garbage.
-Brandon
Just picked it up and drove it onto the trailer!!!
- 20150515_142927a.jpg (930.89 KiB) Viewed 10664 times
Cool, so it's not completely dead. That's good news.
Here is the link to my Facebook page where the updates on this car will be.
https://www.facebook.com/media/set/?set ... 226&type=1" onclick="window.open(this.href);return false;
This is the exact engine sound my car makes when I start it up!!
https://www.youtube.com/watch?v=DXKeqVWdcxY" onclick="window.open(this.href);return false;
I am also getting the Low Oil Pressure Stop Engine message.
So I am wondering if I should try the Motor Flush or pull the heads and just replace the lifters so I can drive it now.
Time to pull the top end off and get some upgraded parts on there? sounds like the lifter collapse, I would have the cam out and maybe pull oil pan in car if it was me... or just redo entire motor if you are up for that... might be lucky and its just in need of the lifters/cam which means you can do all kinda nonsense at same time like headers etc....
xcidmigs wrote:Time to pull the top end off and get some upgraded parts on there? sounds like the lifter collapse, I would have the cam out and maybe pull oil pan in car if it was me... or just redo entire motor if you are up for that... might be lucky and its just in need of the lifters/cam which means you can do all kinda nonsense at same time like headers etc....
I will most likely pull the top end and remove the DOD/AFM since I would never drive slow enough to use it. I have the entire week to mess with this and thinking if I can just get it running now, I can save the money and pull the motor for a proper build when I go turbo.
I thought about the KOOKs but for the cost that is a fourth of the investment for the AFS Twin Turbo system.
Here is the link to my YouTube video of the engine running.
https://youtu.be/Ierz8kaG8CM" onclick="window.open(this.href);return false;
