Headlight upper area?
RMC
Post by RMC »
Are there any lights in the upper part of the headlight?
https://drive.google.com/file/d/1yGfo6g ... p=drivesdk
It looks like there is some kind of connector on the back on the upper outboard side of each headlight assembly. Haven't removed the headlight to see what it is.
(I tried searching headlight but didn't find anything.)
Re: Headlight upper area?
Yea there is a bulb holder you can unscrew. holds a 194 wedge bulb
RMC
Post by RMC »
Thanks for the info.
Is it wired up already?
If so, to what?
Do I need a connector to it to supply power?
Sanford
Post by Sanford »
The bulb is powered by the internal wiring of the headlight assembly. The bulb is above the amber portion of the light and the socket can be removed without removing the headlight.
I put in amber bulbs in mine and I like the looks better than a clear bulb.
RMC
Post by RMC »
Is it wired to the parking/running lights?
Correct the parking lights
NJ_9C3
Post by NJ_9C3 »
To replace this marker light, does it require the bumper to be removed?
Sanford
Post by Sanford »
You don’t have to remove anything except the socket. Pop the hood and they can be replaced relatively easy.
DJ JIM JAMES
Post by DJ JIM JAMES »
My PPV is missing the upper brow light plug does anyone know a part number for it or if another chevy uses the same plug???
RMC
Post by RMC »
