2013 Chevy Caprice Steering Wheel info Button
Wanted to provide free advice for anyone dealing with 2011-2013 Caprice units that have a steering wheel info button on left that is inoperable. Underneath the steering column below airbag there is a connector that is either up fitted or connected to equipment. Simply unplug or change it and your all set.
Re: 2013 Chevy Caprice Steering Wheel info Button
A little more info if you can, I can not access my DIC screen pull up from the left buttons right hand buttons and horn work fine.
I am having the same issue. Please respond with more helpful hints. Or a picture of connection.
Turns out someone programed my DIC to off with a Tech 2, probably a past dealer/ broker it went thru before I bought it. This way a buyer can't see engine idle hours easily. Had Dealer turn it back on....
I thought something was odd as the past owner had changed all the steering wheel switches to no avail.. I have all the Helm manuals and did some research and discovered it could be programmed off, so i had a dealer with a Tech 2 investigate. Hope that helps.
