Front turn signal alarm
VintageIron41
Post by VintageIron41 »
Has anyone had this issue and have a resolution?
2014 Caprice, right front turn signal will blink, then goes to rapid blink with instrument cluster alarm to check right front bulb. I have replaced the bulb ( it's in a tight spot ), no change, then replaced the bulb and holder with the drivers side, drivers side functions normally, right side still does the same thing.
Fudgehog
Re: Front turn signal alarm
Post by Fudgehog »
Did you check your taillight bulb? Typically hyperflash is present when the CANBUS system senses a burnt out bulb, which in your case would be front or rear on the passenger side.
Or if you used LEDs, a resistor that came loose from the circuit. Would also apply to front and rear.
Active Duty USAF
Sanford
Post by Sanford »
My test for troubleshooting light problems is to turn the park lights on and check the brightness on all for corners, then turn the hazard flashers on and see if they all blink the same. If one does some weird blinking, take a look at the ground wiring.
David
VintageIron41
Thank you for your reply's, rear turn signal is working, will try ground check!
