Compatibility between G8 and PPV BCM
Hvychvy
Post by Hvychvy »
I was wanting to get my 2011 9C3 programmed for autostart along with getting it set up for Fog light control using factory G8 harness. Are the two BCMs compatable or will I have to send in my PPV BCM?
Re: Compatibility between G8 and PPV BCM
Post by Pursuit »
Keep in mind that there is no wire/or circuit in the PPV harness from the PPV headlight switch to the BCM. And then there is no wire/or circuit from the PPV BCM out to the engine compartment to where the G8 relay would be. The G8 relay in the G8 fuse box is replaced with a fuel monitoring circuit for the PPV.
Regards,
Hvychvy
Post by Hvychvy »
Thanks for the clarification. Grumble grumble grumble can't be simple :( ..I guess I will try using the tutorial SMWalker wrote.
I am not sure what you mean by "using the G8 harness" as you would have to replace the entire dash harness just to integrate the what 1 wire? for the fog lights. So if you are sending in your BCM for the remote start by all means activate the fog lights feature. But wiring wise you will just be adding on to the PPV harness. Completely doable. But may want to measure the cost of it Vs. what you get. In the 11-13's all programming of the BCM gets you over wiring it around the BCM is the Fog light Icon on the instrument cluster. And hell I am not even sure we have that on there now that I think of it??
