Subwoofers...
Tom Slick
Subwoofers...
Post by Tom Slick » Sat Jan 11, 2014 7:41 am
Anyone added any subwoofers to their car?
I'm trying to decide how to mount the enclosure for my 8" Kicker Solo-Baric L7... I will not screw it into the floor panel or cargo tray...
Was thinking of mounting it to the underneath of the rear deck... any thoughts?
Luckily, I added the amp signal lead to the Quadlock connector while I swapped out the radio!
Later,
Tom Slick
Tom Slick
Re: Subwoofers...
Post by Tom Slick » Sat Jan 18, 2014 3:39 am
Nobody?
Am I the only person installing a subwoofer?
Tom Slick
nick brown
Re: Subwoofers...
Post by nick brown » Thu Jan 30, 2014 6:12 am
lol i guess so. are you using the stock radio with an amp? im thinking about putting some subs in mines also.
2011 CHEVY CAPRICE PPV 9C1 (FIRST OWNER)
2008 CHEVY SEDAN LT
1996 IMPALA SS
1964 IMPALA SS 2 DOOR HARD TOP
Tom Slick
Re: Subwoofers...
Post by Tom Slick » Thu Jan 30, 2014 3:19 pm
I am using the stock radio... I added the amp enable wire to the Quadlock connector so the amp would always be on with the radio...
I have a Kicker L7 Solobaric 8" Dual 2 ohm subwoofer in a ported enclosure, powered with a Soundsteam Van Gogh 400.2 amp.
I have already "popped out" the sheetmetal where the factory 8"s would go, to better allow sound into the cabin...
I was thinking about the possibility of mounting the subwoofer enclosure to the bottom of the rear deck tray, right in the middle...
Later,
Tom Slick
nick brown
Re: Subwoofers...
Post by nick brown » Fri Mar 21, 2014 5:05 am
nice im also looking into the 8 inch subs, and replacing my door speakers. did you use the trunk battery?
2008 CHEVY SEDAN LT
1996 IMPALA SS
Tom Slick
Re: Subwoofers...
Post by Tom Slick » Mon Mar 24, 2014 5:42 pm
I replaced the door speakers already... I do plan on using one of the installed "L.E. equipement" breakers for the subwoofer amp. My big thing is figuring out how I want to mount the subwoofer enclosure in the trunk.
Later,
Tom Slick
greasychevy
Re: Subwoofers...
Post by greasychevy » Mon Mar 24, 2014 10:24 pm
i think G8s have factory subs. maybe even 8" have you looked into how they do it?
2011 9c1 Hugo Blue
Tom Slick
Re: Subwoofers...
Post by Tom Slick » Tue Mar 25, 2014 12:06 am
The G8's have them in the back dashpad... I have a single Kicker Solo-Baric 8" in a ported enclosure already...
Thanks,
Tom Slick
msanti84
Re: Subwoofers...
Post by msanti84 » Thu May 01, 2014 3:43 am
Tom, when you say you added the 'amp signal lead to the Quadlock connector' were you talking about the remote-turn-on wire? Or full audio signal?
Thx.
-santi-
2011 Caprice 91C
1960 Chevrolet C10 - Project
Tom Slick
Re: Subwoofers...
Post by Tom Slick » Thu May 01, 2014 2:08 pm
The amp enable signal, or "turn-on" wire... allows the amp to be on while the radio is on, even when the key is out of the ignition.
Thanks,
Tom Slick
