2014 Remote Start
VintageIron41
2014 Remote Start
Post by VintageIron41 »
What might I need to do to get my 2014 PPV to remote start? I followed the procedure in the owners manual, the lights flash, but no start. Too, alarm/horn function doesn't operate.
Thank you!
cerbomark
Re: 2014 Remote Start
Post by cerbomark »
I don t know what the book says but I know I have to hold down the start button for a few seconds until it starts. I think I hit the lock then HOLD start until I see flashing lights then it starts.
2016 C1
Ilikemtb999
Post by Ilikemtb999 »
Do you have the rpo code for it? Is your check engine light on? It will do as described if your light is on or the hood is open. If the light is not on then I’d start by inspecting the hood latch wiring. It runs to a bulk head connector on the passenger side of the radiator support behind the bumper.
You have to lock it then push and the remote start button.
VintageIron41
Thank you for your reply's, yes, followed the manual instructions, locking first, then start, the lights flash, but no start, will check hood wiring, thanks!
Ilikemtb999
You didn’t answer if your check engine light was on or not.
Post by Pursuit »
I have a 2011 and I have to push the lock button twice, before pressing and holding the remote start button. I added remote start to my car and it took me awhile to figure the two press method. I believe there are other Caprices here and other GM vehicles that require that sequence also.
Ilikemtb999
My 14 you only have to press the lock button once and then hold the start button. I’ve had where the lights just flash and won’t start. It’s either from a check engine light being on or an issue with the switch on the hood latch. Mine originally was because the wire had been exposed to the core support and rubbed thru most of it. Fixed that and it had remote start again.
VintageIron41
Ilikemtb999 wrote: Mon Dec 09, 2019 2:25 pm You didn’t answer if your check engine light was on or not.
Pardon the delay, no it isn't but the hood harness was disconnected at some point, I now have remote start, thank you all who replied!
