Outside Temp?
Outside Temp?
Do these 9C1s have an option to show outside Temperatures? I toggled thru all the options on the display and cant find it, I thought it would be next to the time or maybe on the rear view mirror but nothing.
Walt (AKA:Capeasy) So. Cal.
Re: Outside Temp?
did you check the hvac display ?
Re: Outside Temp?
There is a button on the HVAC controls "TEMP EXT" I think it is labeled. THen it shows up on the upper right of the screen.
Re: Outside Temp?
Thanks , I'll look at that panel a bit closer, I'm still trying to get acquainted with the controls on the panel. been focused on suspension, gear swap and exhaust in these last couple months along with getting a tune put into the car along with disabling the AFM. I feel a little better driving the car longer distances now with that feature turned off. And I finally figured out why my Traction control quit working after the gear swap, it was just a coincidence that the switch went bad at the same time, I messed with that issue for two weeks, so I changed out the switch today and all is well. Now on to the next issue "Dim Headlights" , I'm on Amazon as I type looking up either brighter bulbs or just LEDs.
Re: Outside Temp?
The 2012 display on the center of the dash shows outside and inside temp at the top, toward the right side of the screen.
