Rear running and plate lights not working
Godssondp
Post by Godssondp »
Just acquired the car and realized the rear lights including the license plate isn't working but the brake lights and signals do work. I've not had a chance to do any checking for power. Just wondering if anyone else has run across this issue from when their car was stripped of its police systems. Maybe it's just a headlight switch.
David
2013 Caprice 9C1 Black cherry paint, Iron 6.0, LS3 cam, mufflers, Dod delete, Corvette rims (acquired in July 2019)
2012 Caprice 9C1 White Metallic paint, Iron 6.0, LS3 cam, headers, Dod delete, G8 rims (acquired in June 2019)
2005 Silverado SWB 6.0, sq port #823 ported, .600 lift, 3200 Yank, 4L80e (traded for 2012 PPV)
1979 Mercury Capri 410W stroker, Edelbrock RPM heads & Intake, Rollin Thunder cam, 5-speed, 3.73
Re: Rear running and plate lights not working
If you click your headlight switch one click over to "parking Lights" they are not coming on?
There is a fuse for each side.
THis is Believe the Underhood Fuse panel numbers:
Are the lights at the top of your headlights and the side markers working on the front side bumper? If the fronts are but not the back we may have a snipped wire.
