Removing radio
Re: Removing radio
You got it right! Thanks!
You need any additional contactors?
Tom Slick
Tom Slick
Re: Removing radio
I broke the trim piece that goes across the control panel while removing it... was being a royal pain!
Also, removing the glove box on mine is a major pain in the ass... have to remove the knee airbags... so instead I became a contortionist and was able to disconnect everything...
Btw, the middle A/C vents are screwed to the control panel, ad come out as one piece...
While I have the radio out, I'm adding the following to the Quadlock radio connector:
Amp Signal
DVD Audio RCA connectors
Front Auxiliary audio wiring (for when I get the plug for the USB Receptacle!)
Later,
Tom Slick
Amp Signal
Later,
Tom Slick
Re: Removing radio
Help !
I seem to be at a standstill removing the radio, I can’t seem to be able to remove the top piece of trim that also houses the two center vents. As far as I can tell it should slide out not up. Do you know of anything I’m missing? Or any tips to remove this piece?
Mike
Mike
Re: Removing radio
That piece is screwed to the radio faceplate... comes off as a whole piece...
Later,
Tom Slick
Later,
Tom Slick
Re: Removing radio
thanks got it out but is was a forking cork sucker.. I can see how pieces get broken
Re: Removing radio
Im stuck! None of the pics on this thread are loading for me. And the detailed instructions that are linked are for a 9c3.... whats next on the 9c1?? Do I just pull in the whole front portion?
- 20140703_115302.jpg (1.7 MiB) Viewed 14370 times
2011 9C1 Charcoal Grey--
Chris White programmed Radio
2012 Camaro SS 20's Nitto Invo tires
Re: Removing radio
Got it out! Please disregard the last post
Re: Removing radio
Anyone know where the antenna connector is on the 2014 Caprice PPV? I checked the areas mentioned here and pulled out the radio, but the radio has been changed to a MyLink and looks different. Trying to install Sirius FM Direct Adapter to cut out the static...
Re: Removing radio
Well you might be the only one here with a 2014 so you may have to blaze the trail.
First off do you know what the European antenna connectors look like? They are quite different from the US looking ones. So you may have already seen it. With many US based accessories you have to purchase US to European male and female converter cables. They are commonly referred to 40-EU20 and 40-EU10 adapters.
Then looking at the service manual I can look up a wiring schematic for the 2014 and it shows an external "Radio Antenna Module" where it has a separate output for FM and one for AM but just a single coax cable back to the radio. So not quite sure where you would connect into??
Not sure how well this will show up:
Can you maybe take some pics of the connectors on your radio?
Re: Removing radio
Why don't you just swap the silverbox for one with XM or send me a picture of the back of the silver box it might already have it and I can enable it for you.Newcaprice wrote:Anyone know where the antenna connector is on the 2014 Caprice PPV? I checked the areas mentioned here and pulled out the radio, but the radio has been changed to a MyLink and looks different. Trying to install Sirius FM Direct Adapter to cut out the static...
Chris White
2022 3LT Red Mist Coupe
2023 70th Anniversary Z06 HTC
2023 Escalade V
2022 Camaro ZL1 M6
2023 Escalade V
2022 Camaro ZL1 M6
